80 911 SC, Orem, Ut
Changing interior color!
I want to change from Blue to Black.
I have replaced the seat covers and purchased new door panels. In a 911SC are the Door panel caps and pull handles leather or vinyl? Have any of you changed colors with the dye that is available on these items. How did it hold up?
Rob 1980 911 SC |
abit off center
When I did my 69 I did not change the color but had to replace everything, recovered the knee pads and door tops, door panels etc so it was as much work as a color change. Mine was vinyl so that's why I used. Some are leather and some are vinyl, you should be able to tell if the texture is repeated or peal it back..
The only thing I would use a dye or paint would be the dash pad, all the other stuff is pretty easy to change out.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. Last edited by cgarr; 05-15-2011 at 10:36 AM.. |
