| Jnikic |
05-17-2011 11:40 AM |
Rollbar install
Fist time Porsche owner trying to make the car his own ...
The PO owner of my RSR tribute Targa installed a bolt in cage and removed much of the carpeting in the car (none of it is glued down). While I plan on tracking the car occasionally, it will be more of a weekend toy for me.
I've already received an RS carpet set from AppBiz (thank you!) and plan on installing that this weekend over some sound deadening - I know some will disagree with this, but it meets my needs.
I've already removed the cage ahead of the roll loop, as I don't plan on driving with these pieces installed unless I'm on the track (the go in and out fairly easily).
Now the question: does the cage have to bolt directly to metal, or could I install the cage over the carpeting? I would prefer the later aesthetically - it would make it less obvious the front upright were missing when removed - but if it affects the effectiveness of the cage, I can cut the carpet. Thanks!
