brianhiggi's Avatar
Distributor vacuum question
I'm installing an 1982 ignition distributor on a 1978 SC. The original '78 distributor only had vacuum advance, the '82 has advance and retard. Do I attach the advance vacuum hose to the advance on the new vacuum canister and not plug anything into to retard or what? I do have a vacuum hose going to the non-working air pump, can I use that?
Old 05-17-2011, 10:42 AM
Scott R's Avatar
Yea, leave the retard pot disconnected, you don't need that. Strictly emissions stuff for the later SC's. Just get your total advance dialed in correctly.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-17-2011, 10:58 AM
brads911sc's Avatar
If you are used to the 78, you are not going to be happy with that 82 Dizzy unless you get it recurved...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 05-17-2011, 02:43 PM
brianhiggi's Avatar
What do you predict will be the outcome when I run the 82 dizzy without recurving it? Does anybody know how much a recurve should cost?
Old 05-18-2011, 03:14 AM
