Actually, a second thought - maxing out from Cold pressure - around 2.5 bar, to hot pressure 3.5 bar in about 20 seconds from cold sounds very quick. The warm up phase should take a few minutes. This may be prematurely leaning out.
Brian may have some words of wisdom here - but this does not sound quite right, and would produce the symptoms you describe. Alan |
CIS troubleshooting......
You don't need a running engine to do the following tests: 1). Control, system, and residual pressures. Just a running FP. 2). WUR's could be inspected and evaluated by simply running the FP. 3). Looking for these mysterious air leaks does not require a running engine. There are very simple procedures to do these tests and if a guy like me who have been called "hopeless" could find them, what more about the rest of the community. Tony |
At 75F the WUR will warm up quick and achieve near spec warm fuel pressure in 30 seconds.
Do you have a safety valve in the air filter housing? Has it blown before? Check to see that it is seated properly. What happens if you try to start the engine cold holding at part throttle? (only attempt this if you have a safety valve in place) Have you done the vac leak tests and are confident in the results? Have you pulled the spark plugs on a cold engine? What did they look like? Were any wet? |
I ran the test again and this time I did a better job of watching the clock. It took ~40s instead of the 20s I previously said. I don't know that it makes that much difference -- it sounds like you're thinking it should be happening on the order of minutes. I took a video and posted it on YouTube. YouTube - ‪Porsche 911 CIS Cold and Warm Control Pressure Test‬‏ |
Done 1 & 2. 3 is next on my list. |
I haven't tried cranking with the accelerator depressed -- I was under the impression that was a no-no with these cars. What I have noticed is that sometimes when I cold start the engine I can hear a little backfire and the pop-off valve opening. I think tomorrow morning I will record a video of me starting the car and post it so some of you can get a better sense for what I'm saying. I haven't done a vac leak test. That is my next course of action. A couple of people have suggested using 5-10psi of air. If anyone could outline a procedure for that I'd be very grateful. |
This wasn't suggested yet. I was trying to focus on the fuel pressure tests before I started looking elsewhere. Since they seem to be normal, I think vac leaks are next on the list. I'll try this. |
Send it to Fuel Injection Corp. for rebuild. Goggle them. Call them. Bob rebuilt my WUR and haven't had a problem since. Plus he's a great resource for troubleshooting..
Good Luck and keep us posted. Ed |
Tony,
Could you please explain how to setup this test? Originally Posted by boyt911sc View Post There's nothing wrong with your WUR!!!! 1). The control pressure won't change or increase if there was no power to it. 2). WUR gets power at the same time as the FP. 3). You have unmetered air in your system. It takes only a few minutes to set-up the test and 10 seconds later you're done. Avoid the guesswork and you'll find this air/vacuum leak/s in your system. All you need is a continuous supply of low air pressure between 5 - 10 psi. And PRESTO!!!! They will be right in front of your nose where you least unexpected to find. There are too many possible sources of air leaks in a CIS and some people get lucky by using carb cleaner to find them. But you cannot rely on luck all the time. The test will tell you whether it is leaking or not. No if's or but's. Tony |
There are a few screws inside your air box. remove the air filter and look to see if they look as though they are not screwed in all the way. This is a tell tail sign that you have a cracked air box from a back fire.
They usually crack on the bottom side seam of the box next to the passenger side intake runners (were they tie in the the air box). sometimes you will see a crack along the drivers side seam. I just replaced my air box for the same symptoms that you are experiencing. If it is running a little rich it is probably tuned that way to compensate for a vacuum leak. Hope this helps. |
A new clue!
I was tracing out the vacuum lines so I could start checking for leaks and I discovered that the vac line going to the "vacuum limiter" is disconnected. I believe this is what's called the Auxiliary Air Valve (AAV). Or is this the decel valve? It is right under the FD and has two big hoses on the left side and the vac connection on the right.
I also jiggled the injectors and the ones connected to #4 & #6 cylinder seem to have a lot of play in them compared to the others. #4 is by far the worst. Maybe I need to replace the o-rings on the injectors? Summary of what I know so far: - CIS pressures are good - PO states engine set to run rich - O2 sensor disconnected - vac line to AAR/devel valve(?) disconnected & plugged - airbox looks to be in good shape Maybe AAV/decel valve is bad and was disconnected at some point. Definitely sounds like the richness is to compensate for a vac leak or other issues. If I find a vac leak, it sounds like I'll need to take this someplace that can check the exhaust gases. :mad: Am I on a fool's errand here? |
Subscribed
wur heater ohms
i think the ohms across the wur heater should be 34? if you get an open ciruit then it needs repaired.
Video showing problem
Ok, folks -
First let me say thanks to all those that have offered advice and insights. It is definitely helping me understand the idiosyncrasies of these engines. This is my first Porsche and I'm just trying to take the time to learn everything I can. If anyone is still paying attention to this thread, I posted a video on YouTube showing exactly what the car is doing from cold start. :) The car sat overnight. YouTube - ‪1983 Porsche 911 SC with Cold Running Problem‬‏ Cranks #1 & 2 I just turned the ignition. As you can see, it starts but then wheezes and sputters until it dies. Crank #3 I gave a little gas after it started, but didn't keep the RPMs up (on purpose). It dies again. Crank #4 I gave a little gas after start again, but this time I kept the RPMs above 2k. What you can see is the RPMs bouncing around a bit under and over 2k. What you can't see is that I'm trying to keep the accelerator constant. It seems like there is a slight delay between what I'm doing with my foot and what the RPMs are doing. I only need to keep the RPMs up for a few seconds and then it settles in at a normal idle. If any of you gurus out there can tell me anything insightful, I would appreciate it. :) Here's where I'm at: 1) Still need to figure out whether it is the AAV or decel valve that has it's vac line disconnected. 2) Why would it be disconnected? 3) Going to search for vac leaks next. If I can figure out how to used the compressed air method, I will do that. If I can't, I'm waiting on a halotron fire extinguisher to arrive and then I'll use the carb cleaner method. |
Is this the AAV or decel valve?
There seems to be a great deal of confusion in other threads on this forum as to what this thing is. It is labeled "vacuum limiter" on the vac diagram on the underside of the rear decklid. Is this is AAV or decel valve? Why would the vac line be disconnected?
http://forums.pelicanparts.com/uploa...1306776631.jpg |
As I mentioned in an earlier response, my car does/did pretty much the same thing yours was/is doing. But earlier in this thread is a response that says the responder has been able to tune this behavior out of cars. One of his tips is to remove and plug the vacuum retard line, which my car has, and retime it. I did that and it's made the car much easier to start.
Now, my wrench wants that line connected, so I'm in a bit of a quandry. What seems plain, though, is that without it, the car starts better and off-idle throttle response is a whole lot improved. |
Thanks for the post. I'm still trying to sort out what has been done before I bought the car and why. The AAV/decel is the latest puzzler. I have a feeling some things were done for a reason - either it was to improve performance or it was to fix another issue. Perfect example is your wrench. Why does he suggest leaving it disconnected? I'm not arguing. I just want to understand. |
CIS troubleshooting.......
PM me your email and will forward a detail description of the process including some pictures. Tony |
Ok, folks -
First let me say thanks to all those that have offered advice and insights. It is definitely helping me understand the idiosyncrasies of these engines. This is my first Porsche and I'm just trying to take the time to learn everything I can. If anyone is still paying attention to this thread, I posted a video on YouTube showing exactly what the car is doing from cold start. The car sat overnight. tirwin, I watched your video. That is precisely the behavior I described in post #11 and everything you need to solve the problem is in that post. Good luck. |
5string, Maybe he wants to reconnect it for an emissions test. The vacuum retard is a device to reduce HC emissions at idle to meet a specific test. Porsche made a compromise of settings to meet the test and still have decent drivability when the engine was new. Unfortunately, CIS lambda does not have active idle control and ECU controlled timing to compensate when the engine ages like a modern system and you have to find the right compromise of settings for your engine through tuning. |
I subscribed earlier, very interested in your progress and updates. My car starts/reacts almost precisely the same as yours. Although I've come to live with it for several reasons. One of these days I'll get a set of gauges and re-request boy911's advice w/ some numerical data to report.
Morbid curiosity, if you take off the air cleaner and depress the air valve arm for a few seconds w/ the key on before cranking, does it start right up? I have 2 likely suspects and a side issue with mine (seemed to start easier when ambient temps were in say 50's, now that we are in 80's 90's it's a little tougher, I have theories...), interested if your follows the same paths |
Thanks for the reply. I had forgotten about your original post. I guess I was so focused on the CIS pressures and the WUR that I didn't fully appreciate the wisdom of your post at the time. Now I completely get it. :) So here's what I'm going to do. Remaining parts for the tune-up are coming in at the end of this week. It will probably be next week before I make any more progress. First, check for vac leaks. Boyt911sc offered to send a procedure. I'm expecting to find that at least one or two injector o-rings are leaking and possibly some other places. Once I get that fixed, I'll move on to the tuning you suggest. When I do the tune-up I'll check the condition of the plugs and check dwell and timing as you suggest. One question I have is this -- I have been repeatedly cautioned that having the proper exhaust gas balance is critically important. Since I don't have an exhaust gas analyzer, I don't have a way to measure the effect of changing dwell, timing, mixture, etc on exhaust. What do other DIYers do in this situation? Gunsons seem to run around $200. How accurate are these units? Are they worth the money? Is this a MUST have or a NICE-TO have for the average DIYer? |
tirwin,
When you are confident that your pressures are correct and you have no vacuum leaks with a propane torch, the duty cycle of the FV gives you an accurate proxy of the average mixture and allows you to make adjustments without a gas analyzer. I have confirmed this with a CO analyzer and a wide band 02 sensor. CIS lambda is correcting the mixture back to stoich at idle if the system is working properly. If the closed loop duty cycle is high, the open loop mixture is lean and the system is bleeding off lower chamber pressure to richen the mixture. If the closed loop duty cycle is low, you know the basic setting is rich and the system is raising pressure to lean out the mixture. The system is very accurate around stoich and once you know it is working correctly, it is very easy to make accurate mixture adjustments. Since the system corrects the mixture at idle or cruise, these adjustments really only effect the average mixture in open loop, i.e. WOT or cold running. If the engine is running, reading the FV duty cycle for 5 minutes will give you more information than a week of guessing. Unfortunately for your issue, you have only one shot at a cold start a day if you are striving for the factory drivability of instant firing and high cold idle at the first turn of the key without throttle. You make a small adjustment after the car has been driven for a few miles, then you wait a day to test the result. Disconnecting the vacuum retard and resetting the timing is the first step before any mixture adjustment. Most SC's with CIS lambda that stumble and stall at starting cannot tolerate a slightly lean mixture when the retard kicks in and kills the idle. Without an active idle control and ECU timing, there is no one to catch it. That is when you try to do it with your foot and cause other problems. |
Time for an update...
I finally gorgeous time get back to the car. Sprayed carb cleaner at injectors, intake manifold and any other place that had a vac line connected. The only place I could find an obvious indication of vac leak was at the intake. One of those smoke machines would be really handy right now. :( Someone suggested using compressed air. I assume this would involve disconnecting the intake manifold and making some kind of adapter to connect the air compressor hose and seal the opening? If anyone has any details on that, could you please post it?. I'm really not confident I've found the only leak. |
stupid iPad auto-correct |
For pressure testing the manifold you cold use one of the adapters from the following site.
Intake Leak Pressure Tester Just hook one of the appropriate size to the manifold intake and pressurize with compressed air from a tire inflation nozzle. You could probably use a bicycle pump if you don't have an air compressor. J |
Hi
i am also interested in testing for air leaks, but not sure where to connect the air line or pump, any pics ? When I remove the oil cap the revs only drop 50-100 rpm? thanks |
***UPDATE***
Well, folks... I'm long overdue for an update. Sorry it hasn't been sooner. Unfortunately family and work sometimes comes before p-car obsession. And I know what some of you are thinking... I need to get my priorities in order. :) First, a little recap... I started this whole thread with what I described as a cold running problem. Car starts fine, but then sputters, chokes and wheezes until it stalls. Giving gas after ignition and keeping RPMs up around 2k for ~30s was the workaround. After that it was fine. Other facts about the car: - PO stated O2 sensor was disconnected so it constantly runs in open-loop - PO also stated that AFR was set "a little rich" - 65k miles on the car (no rebuild on the engine) - car has had about ~10k miles put on it in the last 10 years - vac line to decel valve is disconnected and plugged Initial step in troubleshooting was to check the CIS fuel pressures. Everything checked out ok. Checked the WUR. It was working correctly. No joy in finding the problem. I was scratching my head. A lot. Some people suggested it was the fuel distributor. Others said it was a vac leak. And even others said it was a tuning problem. All by the way, are very likely suspects. First the good news. As I write this, the problem <knocks on wood> is solved. (Crossing my fingers, holding a lucky rabbit's foot, throwing salt over my shoulder...) I hope my declaration of victory is not premature, but it sure looks that way right now. Now the bad news. I have absolutely no idea whatsoever what I did EXACTLY that fixed it. There. I said it. And I'm not ashamed to admit it. I am confused. I am of course happy that it seems fixed, but that little engineering voice in my brain is screaming that it must understand how this happened. Theory, meet Reality. Reality, meet Theory. This past weekend I did a tune up, so I did several things. Here's what I did and found along the way. - Drained the oil. Not bad. PO said he used Mobil 1 15W50. Minor amount of debris on the magnetic tips of drain plugs. - Oil drain seal at the crankcase looked to have some seepage. Removed the cover and checked the screen. Very clean! Only one gasket though. Supposed to be two. Installed in the following order: gasket, screen, gasket, plate. Installed new washers and nylock nuts. - Installed new Mahle oil filter. - Removed upper & lower valve covers. Saw a lot of oil build up around the outside. Seems like there was some leakage. Cleaned it up so I could see if comes back later. Gaskets were brittle and mostly snapped off in pieces in my hands. I had to be extremely careful with removal. - Adjusted valves. Hardly any adjustment needed, if any. - Pulled the old Bosch spark plugs. I was expecting to see plugs on the fouled side, but they were a nice tan color at the tips. None seemed noticeably better or worse to me, but I don't do this for a living either. - Installed new NGK plugs. - Replaced OEM plug wires with a new set of Clewetts. - Replaced the rotor and cap. - Installed new VC gaskets and used new washer and nylock nuts. - Put in 9 quarts of Mobil 1 15W50. - Installed a new air filter (actually did that about a month ago). By the way, I wasn't expecting this to solve the cold start problem. I was just doing it because I figured that if I was going to muck with AFR and timing, I should start with a good baseline and I wanted to have a good maintenance checkpoint anyway. So I did all this work thinking I was going to run it for ~30s at first just to check for any leaks. Dang if it didn't fire right up and idle perfectly at 1k RPMS! It has NEVER done that in the 5 months I've owned it. After I got over the shock and amazement at what I was seeing, I checked for leaks. None. Excellent! Turned the car off and waited a few minutes. At this point, I am now questioning to myself whether I saw what I just saw. The next test was the real biggie. I started the car again. And it started! In the past if I turned the car off before it was good and warm and then re-started it, it was VERY hard to start. Definite improvement here, but still might be a fluke. I let it sit over night. The next morning I started it again and it started right up. Wow. Took it for a test drive. No issues. This evening I started it again and went for another test drive. Still no issues! So what fixed it? I haven't checked the timing yet. I'm almost afraid to change anything else at this point. Well, I'm happy that it seems to be running better of course, but not knowing how I fixed it drives me farkin' batty. Just want to close this post by saying thanks to everyone out there who chimed in to help a newbie like me. This is a great forum and fantastic resource. I'm always amazed at how people are willing to share their expertise and experience. I could not have come this far by myself. That is for sure! I could've taken the car someplace and said "fix it", but there sure is a great deal of satisfaction that you get when you are your own wrench! Stay fast my brothers (and sisters)! |
One more thing I forgot to mention... I need to give a shout out to Wayne for this website and the parts! I bought everything I needed from Pelican and the 101 projects book was at my side the whole time!
Ambient temperature.
Glad you got it sorted out so easily. As an engineer you should know only to make one change at a time. No worries, just drive it and be happy.
*** UPDATE ***
I'm proud to say this case is closed! For those of you who might be late to the thread, here is the original video I posted showing my cold running problem: ‪1983 Porsche 911 SC with Cold Running Problem‬‏ - YouTube Here is the video I took this afternoon of how it runs now: ‪1983 Porsche 911 SC - Cold Running Issue SOLVED!!!‬‏ - YouTube Took it to German Car Repair in Roswell, GA and had them run a smoke test on it. (As an aside, owner Alan Kidson and Jerry the Porsche mechanic are top shelf guys.) Good news is NO VAC LEAKS. Left the smoke machine on for quite a while and nada. Once vac leaks were ruled out, Jerry adjusted the WUR and bingo -- perfect idle! In summary, doing the tune-up was a piece of the puzzle (new cap, rotor, plugs, plug wires = better spark) and the WUR adjustment was the final piece. Woohoo! Now I'm on to other projects on the car! :D |
Glad to hear.........
Tirwin,
It must have been a great relief to get your car running again. Did you ever try to check your control pressure? Even without running the engine, you would know if the cold control pressure was within spec. I will make a bet that your mechanic found out that the cold control pressure was too HIGH and made the necessary correction. Keep us posted. Tony |
Control pressure was checked and it was well within spec. Don't recall the exact number off hand but it is in my notes. |
From your previous post........
tirwin, You mentioned in your previous post that the mechanic (Jerry) made adjustment in the WUR (????). Then it must have been off spec? Listening to your first video when you were trying to attempt to start the engine multiple times, it seemed that you were depressing the accelerator pedal to help the engine run. Was that the case? So what work was done to your car? Keep us posted. Thanks. Tony |
What I'm saying is that the control pressures were not out of spec, but that doesn't mean they were optimal either. It was running too lean on cold start so the adjustment that was made was to richen the mixture a little. Since one of the purposes of the WUR is to enrich the mixture on cold start, it seems to me that it wasn't enriching the mixture enough. Like I said, the biggest difference in behavior came after the tune-up. In a previous post I gave a pretty thorough explanation of what work I did, so I'm not going to belabor that here. But my belief is that the tune-up meant better spark, which meant better fuel burn. I also had the shop re-time the engine because I did not want to start making any adjustments until I knew for certain I did not have any vac leaks. Otherwise whatever tuning was done would just be covering up another potential problem. So, no one thing was the ultimate fix, but a combination. In the first video I cranked the engine four times. On cranks 1 & 2 I did not depress the accelerator. On crank 3, I depressed it just enough to catch it from initial stall but not enough to sustain it. On crank 4, I depressed it and tried to keep the RPMs above 2k. It looks like I was "goosing" the pedal but I wasn't -- I was trying to keep a constant and even pressure on the pedal. As you can see, there was a significant lag in the throttle response (and a hair difference in just enough and too little). You obviously can't see it in the video but when you see the RPMs surge I had actually depressed the pedal around 1-2 seconds prior. The moral of the story is that my experience affirms what many people have said on this forum -- this is more of a tuning problem than a parts-swapping problem. I can see how it would be very easy to just start changing parameters like AFR, timing, idle, WUR, etc and get yourself in a real mess. My advice for others who have this issue is to start with the basics and work through everything methodically. |
Please report back in October, I'm keenly interested to find out if the problem is still solved when the temps drop.
I've definitely noticed a "sweet spot" with mine, below it and above it she's grumbly at first. Wondering if you have just tuned right now for current (hot as 7 hells) conditions. This is not derogatory, thrilled for you it's solved, it's a curiosity on my part. |
| All times are GMT -8. The time now is 07:16 PM. |
