1992 964 Turbo - Were is speedo cable connected to?
Hey guys, im having a bit of trouble here
I have a 1992 964 turbo porsche, it is manual and was originally left hand drive. I was wondering if anyone knows were the speedo cable connects to? eg gearbox, diff, etc Your help would be greatly appreciated!! |
Are you sure it has a cable? I thought Porsche did away with the speedo cable in the mid 70's?
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
if its a 92 it is electronic ... unless someone backdated the speedo ........
you should ask on the 964 forum, this one is for the old school 911 (to 89). you car doesn't have a cable, it should be a sender (2 wires in sheath coming out of it) about size of silver dollar in a recess in the trans.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Insert Tag Line HERE.....
No cable, it has a sensor on the drivers side trans case right above the axle.
It it fed from the r/f wheel speed sensor. There is a blue relay in the fuse board that takes it from the abs and feeds the speedo
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
964 speedometer not working issue ... solved.. |
