"farking Porsche hero"
SWB fire extinguisher mount
After reading the fire extinguisher thread, I decided better safe than sorry. I picked up a 2.5lb Halon bottle and after spending an hour trying to figure out where to put it, I came up with this mounting solution. It utilizes the stock inboard seatbelt mounting locations. I cut and bent a couple 1"x1/8"x4" metal pieces, bolted them to the car using the seatbelt holes, and bolted the extinguisher bracket to those. It's in easy reach when harnessed in, fairly out of the way, and I didn't put any new holes in the car. No one will ever sit in the back seats, so that's not an issue.
![]() ![]() Not a bad way to spend a Saturday morning.
Rich '66 911 #303872 '07 Cayman '17 Macan '58 Land Rover S2 88" |
Banned
I mounted mine directly to the tunnel cover. Just used sheet metal screws.
Nice and clean.
Scott '86 911 Carrera Coupe, PCA, PBC |
Thats exactly where i put mine but my extinguisher is a bit shorter. I also didnt screw it in very well i think just the carpet is holding it. I need to fix that
82 SC , 72 914 |
Great Set Up
THANK FOR POSTING!
M-74 |
Nice solution.
Nice interior ! What kind of belts are those ? 3 point ? Who makes them ?
Du must schwein haben '67 901/05 rebuilt 2.2 Bultaco Metralla 62 "XDina" '68 BMW R69S |
It's a Crow Rotary Kam 5-point harness.
