Auto Sport Engineering Fuel Line to Accumulator
Len At Auto Sport Engineering Made a Fuel Line for me. As some of you already know, From 1978 to 1983 Porsche 911sc has a fuel line between the Accumulator and the main fuel line from the Fuel Pump. This line is No Longer available from Porsche or New From Anyone.
I cut mine before I knew this to put in a 1 way valve to have extra protection in pressure leakage. The Valve I got did not handle the pressure (They said 75 PSI more like 30 PSI) Then it was too Late. SO I made up some fittings and put the Old one back together. I needed a 45 degree Male center to make it perfect but it worked. Here are Pics of my old line and Len's New Line. Fit like a well worn Glove and NO Leaks. I did use a rubber abrasive wheel on my Dremmel to polish up the end to make sure of the seal. Thanks Len ![]() ![]() ![]()
Made History at Daytona and Still one Fast Old Man! 1982 Porsche 911 SC & 2017 Honda Si |
