rfuerst911sc's Avatar
SDS fuel injection ECU- what are your results ?
I have a 1978 3.0 installed in a 914/6 GT clone. I'm currently running Weber 40's for induction but I've recently purchased a Carrera intake system with plans to install in place of the Webers. So far I have the manifold, fuel rails, fuel injectors, throttle body and fuel pressure regulators that come with the OEM setup. If going SDS I will need a TPS, air and head temp sensor correct ? And then their hall sensor magnet setup for the crank pulley ? I will add a wideband O2 sensor also. Does it sound like this is pretty much it ? For ignition I have a OEM SC distributor that was recurved by Jerry Woods to run with the carb's and it's being driven by a Mallory Hyfire CD multi spark box. I know there are guys out there running SDS how have they been since putting some miles on them ? Any regrets ? Car is/will be street/AX/DE.
Old 05-21-2011, 08:53 AM
