Sealant for 915 drain plug?
Folks,
Changing all the fluids in my Targa. Happy to say that the magnets in the sump drain, oil tank and tranny were free of any metal or filings. What should I use on the threads of the transmission drain plugs as a sealer?
Thanks,
Wade
-Wade
1972 Targa, nothing matching.
Looking for motor 6124265 and transmission 7720299
Old 05-24-2011, 07:12 AM
3.2 CAB's Avatar
Hi, are you talking as in addition to the crush washer? I have not used any loctite or sealer before on the trans. drain plug, I just use a fresh crush washer, and it does not leak. I guess that it probably wouldn't hurt if you did put a little sealer or silicone toward the head end of the drain plug along with a new crush washer. Maybe others will have some additional ideas for you. Good luck.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 05-24-2011, 07:18 AM
Almost Banned Once
sc_rufctr's Avatar
Normally you wouldn't use anything. However as our cars get older they can leak.
If you have a problem you could try Teflon tape on the thread of the drain plug. The same stuff plumbers use for taps.
Also... You could use some Curit T. Our host sells it.
Porsche 911 Engine Rebuild Kits (1965-89) - Page 4
- Peter
Old 05-24-2011, 07:22 AM
My drainplug (73 915) does not have a crush washer but just a threaded plug. I will use a little Curil, thanks.
W
-Wade
Old 05-24-2011, 07:58 AM
Checked out
McLovin's Avatar
it's a tapered plug. no sealant is used.
Old 05-24-2011, 08:11 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
It's an NPT thread and doesn't use a seal surface like more modern engine plugs. Use antiseize if anything and don't overdo the plug when torquing it.
Also, if yours is the one with the recessed hexagon pattern I would change it to one with the protruding hexagon since that one allows for more torque when you have to remove it later. The recessed version can strip easier.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 05-24-2011, 09:03 AM
Thanks for the response
W
-Wade
Old 05-24-2011, 09:06 AM
