Brake pad warning light
My ride is a 1984 911 Carrera. Brake pads were recently changed 200 miles ago.
Brake pad warning light comes on when first starting the car then goes out. But after driving a few miles (10 miles) it comes back on and does not turn off unless the car is off. Then if I start the car comes on just during starting. Then again after a few miles back on again. I don;t feel anything strange. Brakes work.
Any ideas?
pkp
Old 05-21-2011, 07:27 PM
Aircooledmagic
aircooledmagic's Avatar
You may have burnt through the minimum brake wear sensor..before you had the pads changed.
Old 05-22-2011, 04:01 AM
dshepp806's Avatar
I always change those out WITH the pads....sure sounds like what you're seeing. May want to doublecheck the connections (at minimum).
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-22-2011, 05:31 AM
Guys thanks. What happens if I keep driving. Would it hurt anything?
Old 05-22-2011, 06:59 PM
QSYSOPR Extrordinaire
Nope. It's just a completed electrical circuit to light up your dash. It is a nice little reminder to have though. I just put new pads and sensors on my '85.
Old 05-22-2011, 07:54 PM
Thanks tubbyaz
Old 05-22-2011, 09:29 PM
