Engineer of profanity
924CarreraGTP's Avatar
Zenith 40 tin diaphragm leaks
I got my 1970 911 running. It idles but not that well but runs good. I noticed the diaphrams under the throttle cams were leaking. Can I replace these without having to retune the carbs? Can I replace these without having to remove the carbs? Nothing else looks to be leaking so why disturb it? The car runs good.
Thanks,
Justin
Old 05-22-2011, 04:24 AM
VFR750's Avatar
Do you mean the 3 acceleration pumps or the enrichment system. Either way, you could replace them with out a full teardown. You would have to check the acceleration pump operation after you reinstall the linage. I think cleaning the gasket sealing surface will be hard to do with the carbs installed.
Old 05-22-2011, 04:31 AM
I think I can do it. It's the accelerator pumps. I have some special tools I made for cleaning gaskets out of tight spots. It just sucks that I have to spend $60+ on a complete rebuild kit to replace only the diaphrams.
Old 05-23-2011, 01:02 AM
ratpiper71T's Avatar
I would rebuild the whole carb(s) if I were you. You're probably sick of spending money and time to try and get it running, but noting from your other posts that I been sitting a while- no telling what buildup and crap is stuck in the passages. You'll probably have to block off the aux. Enrichment system. Here's some links:
Zenith Carbs
Zenith 40TIN service and design review
Zeniths on Stock 2.7L
Old 05-23-2011, 06:20 AM
