Agfours
Accuracy of VIN Lookup?
I just looked up my VIN for kick and grins at the ***********.com site and based on the result it states I have a 40% LSD, option M220....hmm...news to me.
This option was not on my Porsche COA, and I don't have a decklid sticker to verify this. I recently put non-LSD Kendall in my 915, so I'm now worried I need to swap it out for LSD additive version ASAP... At the same time I was putting the Kendall in, I rotated the rear wheel, and the other wheel didn't rotate, leading me to believe that it was a non-LSD diff. (prior experience on American cars with non-LSD diff however, the opposite wheel rotates in the opposite direction...does not stay still... Just saw another post, and guess I need to look for the '12' stamp on the case, but first curious about source of info for these VIN decoders, and accuracy before i have to get under the car again. Also, anyone think I need to give immediate attention to swapping the Kendall for LSD version, or have a recommended aftermarket LSD additive I could use with the Kendall? Thanks!
Paul Present and accounted for: 1986 Carrera Coupe, 2021 Audi SQ8...Gone but not forgotten: 1987 Carrera Coupe, 1996 911 Carrera C4S, 1985 911 Carrera Cabriolet M491, 2011 Cayenne Turbo, 2001 Boxster S....Me: "What is your return policy?" FLAPS rep: "We really expect you to keep it..." |
Capitalist and Patriot
From my experience they are hit and miss like most option/VIN decoders for our older cars. Newer cars produced after 1990 seem to have better results according to my buddy who is a GM at a major auto dealership.
Are you sure you have the original trans in your car? Does the trans number match the # on the COA? No comment on the trans fluid, but I suspect you don't have the LSD from the info you've stated so a change or additive might not be necessary? YMMV
Former Test driver & Production Manager Singer Vehicle Design 2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold) "Dream it, Believe it, Decide it, DO it " |
Checked out
For our 25 year old porsches - they are never accurate.
RETIRED
Lift the rear onto jack stands...spin the wheels.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Agfours
Did that as per my post. Other wheel did not turn at all. Would have expected opposite rotation on non-LSD....thus part of the question.
83 911 Production Cab #10
[QUOTE=agfours;6045267]... I rotated the rear wheel, and the other wheel didn't rotate, leading me to believe that it was a non-LSD diff... QUOTE]
Ask basically the same question because my COA list LSD and P.Z. confirm that for a non-LSD, one wheel will go clockwise while the other will go counter clockwise. So if you turn one wheel the other wheel is not rotating it should a LSD.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 05-26-2011 at 03:56 PM.. |
