I replaced the clutch, flywheel and throw out bearing in my '86 about three months ago. When engaging from a standing start on close to flat ground it's fine but when I'm on a slight uphill the cars shudders and shakes until the clutch is fully released. Is this caused by a worn helper spring or what?
Senior Member
This is usually caused by insufficient pressure on the Bowden Tube. The hard tube encasing the rearward part of the cable shoudl be pinched so hard against the fire wall that it bows upward and stays away from the throttle linkage.
I have a related question. I had a little shuddering - actually it was a LOT of shuddering once trying to exit quickly from a stop light. So I looked and decided to put more pressure on the Bowden Tube. Here's the question: increasing pressure on the Bowden Tube reduces the 1mm gap created at the small locking bolt during the adjustment procedure. Does this mean I must adjust the bopwden tube, basically at the front (pedal) clip? Another formn of the question goes like this: If the horseshoe spring is going "over the top" and there is at least SOME gap at the small locking nut under the tranny, is my clutch adjusted fine? That is, am I sure there is no pressure on the TOB, as long as there is a gap at the locking bolt? ------------------ '83 SC |
Try tightening up the Bowden tube - if there's *any* play at all, the cable will "bounce" on the lever, and the car will shudder like this. A general adjustment of the cable can cure it. I ran into this problem when I replaced my cable.
------------------ Mark Szabo 1986 911 Targa 3.2 1987 Escort 5-speed 1.9 RIP The Porsche Owners Gallery |
i hope that you machined the flywheel!no? well that's probably the reason for the shudder!you gotta do it with every clutch job!
I actually installed a new flywheel from Vertex.
oil from mainshaft seal, loose engine to trans nuts, deteriorated eng/trans mounts, pressure plate warpage from uneven tightening, new flywheel warped. if the outside stuff is in order you'll have to pull it again. the bowden tube made all the difference in VW's, but i've never noticed any related problems with 911s. the only adjustment on it is for pedal height.
True, if the clutch cable is routed correctly, each and every time it is replaced, or every time the engine/transaxle is installed back in the car ... it will not cause any problem! However, many of the people on this board are replacing the clutch cable, or the clutch itself, for the first time, and at least two people here, within the last year ... had the cable routed wrong and it WAS CAUSING a shudder problem, only upon takeoff in FIRST GEAR! So, it is worthwhile to check to see if the end of the Bowden Tube is firmly seated against the firewall, and that there is tension pushing it against the forward (firewall) end at all times!
------------------ Warren Hall 1973 911S Targa |
Buy them, sell them
I've noticed that my car does it in reverse! Although it's starting to do it in 1st also. The clutch is only about 3k miles old. I'll take a look underneath on the weekend.
It's a pretty straightforward job to do, right? ![]() AC ------------------ Adam Chaplin - 1976 911 Coupe My Pelican Gallery Page My Owners Gallery Page |
Folks,
again, funny to see an the group having an exact description of the symptoms I am seeing.. shuddering in first gear when starting, that gets worse when hot, but where the clutch does not seem to actually be slipping in higher gears. Being mechanically competent, but a 911 newbie (in terms of opening it up at least) can I fix this bowden tube thing myself? hugh |
My cluch starts to shutter when I'm in heavy traffic. I think the clutch is getting hot and causing this. I don't know the mileage on my clutch but is this a sign that I have a clutch replacement in my future?
Also, I have an 87 so I don't think I have a bowden tube. Thanks, Don 87 coupe |
Adam,
You should not have any trouble checking the Bowden tube, or adjusting your clutch's freeplay, since you don't have to worry about the horseshoe spring! ------------------ Warren Hall 1973 911S Targa |
Take a good close look at John Walkers posting of 3-20-01, and use it as your boilerplate for bugging out the shudder problem, starting with easiest to access, which would be the motor and transmission mounts/bolt check, and work your way towards the deeper more involved scenarious.
