Brake pad warning light
My ride is a 1984 911 Carrera. Brake pads were recently changed 200 miles ago.
Brake pad warning light comes on when first starting the car then goes out. But after driving a few miles (10 miles) it comes back on and does not turn off unless the car is off. Then if I start the car comes on just during starting. Then again after a few miles back on again. I don;t feel anything strange. Brakes work. Any ideas? pkp |
Aircooledmagic
You may have burnt through the minimum brake wear sensor..before you had the pads changed.
I always change those out WITH the pads....sure sounds like what you're seeing. May want to doublecheck the connections (at minimum).
BEST! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Guys thanks. What happens if I keep driving. Would it hurt anything?
QSYSOPR Extrordinaire
Thanks tubbyaz
