khamul02's Avatar
Porsche Crest Motive power bleeder question
I read on this thread pinch off that you need to pinch off the overflow hose.. I'm assuming this is one other than the one right on top of the reservoir. Can anyone point me in the direction of what needs "pinching"?
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 12-30-2010, 05:21 PM
HarryD's Avatar
It is the hose on the top of your reservioir that points to the driver.
Note nipple on left side top of reservior.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-30-2010, 05:46 PM
80 911 SC, Orem, Ut
RSWiser's Avatar
Just connect the power bleeder and pump it up. You will find the hose real quick.
I did!
Rob
Rob
1980 911 SC
Old 12-30-2010, 05:59 PM
dshepp806's Avatar
clamp it, for sure,..be sure NOT to damage or compromise it when doing so.
Doesn't take boatloads of pressure, BTW,,,cover your interior bonnet nicely,..so as to prep for worst case!!!!!!! Especially if it's your first time......There was guy who pumped great amounts of pressure and created one helluva (unprotected) mess on his carpet......of course, this is gorilla intelligence, magnified....funny read, I must say.
I like this methodology,....I may say goodbye to it soon, once the speed bleeders are installed,..but it has served me well.
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 12-30-2010, 06:12 PM
Hodgey's Avatar
+! on what he said as to the location.
I used a pair of small locking pliers having first wrapped the tube with an old polishing cloth so as to eliminate damage to it.
Worked a treat.
I installed speedy bleeders too on the front calipers.
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 12-31-2010, 06:23 AM
JMatta's Avatar
Awfully clean mechanicals there...newly restored?
'73 911 Frank 'n Meanie
2002 Boxster S
PCA Instructor Circa '95
Old 12-31-2010, 06:30 AM
Sounds like you're using a new Motive, in which case the plastic hoses on it should be in good shape. Mine was about six years old when it blew a hose under normal pressure last summer... not a fun experience to clean up. Anyone reading this: if your Motive is more than five years old, go to Home Depot, buy new plastic hose and replace it before it blows!
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 12-31-2010, 06:40 AM
GaryR's Avatar
Send a message via ICQ to GaryR
I use a 3" piece of hose with a bolt hose clamped in one end and just pop off the overflow hose and clamp on my blocker hose. I believe those pics are of an older car, my SC's hose points to the fuel filler area.
Gary R.
Old 12-31-2010, 06:43 AM
khamul02's Avatar
Outstanding!! I'm off to give it another try.
Tom Hutchinson
Old 12-31-2010, 07:10 AM
efhughes3's Avatar
Ditch the Motive, and use speed bleeders!
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 12-31-2010, 07:19 AM
I like the speed bleeders idea, but haven't tried them.
I use the Motive system but don't put fluid in the bottle to avoid all sorts of situations where fluid can get where you don't want it. This also reduces the clean up. This method requires watching the level and taking the cap on and off to refill. For a car that nice I would not risk putting fluid in the Motive canister.
Old 12-31-2010, 08:12 AM
Why not just connect the pressure bleeder to the vent hose?
Sherwood
Old 12-31-2010, 09:27 AM
Hodgey's Avatar
[QUOTE=911pcars;5756231]Why not just connect the pressure bleeder to the vent hose?
Sherwood,
You could do that, but in my opinion it's easier to use the filler cap orifice and just crimp the overflow.
I also agree with hcoles re using only air pressure,, not fluid in the bleeder. I only went up to 10 psi and my pedal is firm and high...much improved.
I must have more money than sense because I bought and installed speed bleeders and bought the motive.....what was I thinking??? LOL
At least I can do the flush quickly and use the speed bleeders to fine tune.
Neil
Old 12-31-2010, 09:46 AM
HarryD's Avatar
I agree, wish I could say it is mine but it is not, it is Bob Tilton's.
Harry
2020 MB E350 4Matic
Old 12-31-2010, 09:51 AM
[QUOTE=Hodgey;5756264]
Sherwood,
You need two bleeding systems to remove air bubbles? If so, rethink strategy, and don't forget to crimp the vent hose. BF loves paint.
MHO.
Sherwood
Old 12-31-2010, 10:13 AM
Hodgey's Avatar
Sherwood....
No I don't need two systems for brake bleeding; I was just realising that I had in effect purchased two systems by buying and installing the sped bleeders, AND bought the Motive bleeder....
I suppose now I can choose which one depending on how lethargic I am feeling
Neil
Old 12-31-2010, 12:10 PM
those things pump up so slowly that i drilled a hole in the top and installed a metal tire valve stem. about 2 seconds with the air hose instead of 2 minutes hand pumping.
206 637 4071
Old 12-31-2010, 12:20 PM
Hodgey's Avatar
JW...that is definitely the way to go if anyone already has a compressor in the garage....unfortunately I do not....
Neil
Old 12-31-2010, 12:27 PM
John W
JW probably bleeds more brakes in a week then I'll do in a lifetime so the pumping isn't all bad. A small C clamp works great to close the vent hose.
John
89 3.2 Targa 123k miles
Old 12-31-2010, 01:01 PM
efhughes3's Avatar
HF sells plastic hose pinch pliers. I got a set of three sizes for like $5, they've come in handy other times.
Old 12-31-2010, 02:53 PM
