I've seen that done also with 30 amp relays, with good results.
Or could I take a existing fuse block and transplant/swap it, i.e. a low 5 or 8 amp block and place the "springless" block there? Jim |
It's wire in parallel with the stock relay, and sort of operates as an adjunct, but you abandon the old relay. The fuse block can be replaced wholesale.
I need to replace my ac switch, or I'd have scanned mine with my infrared, and have given you my reading as a data point for you. Hopefully this weekend I'll have time to do it. :) |
I think that fuse runs the clutch. I wonder how many amps it's drawing. You say it heats up pretty fast?
Swap blocks...sure, but not an approach I would take. |
Problem solved. A/c relay not working. Nice that many are interchangeable.
Thanks again.:D |
Hey Rusnak, the fuse get's so hot it literally melts the fuse and shrinks then cuts the AC off. The other day while driving around on stage 3 "HI" I smelt burning plastic followed by a flickering AC Blower, System literally going on and off by itself. Jumped out and the fuse melted yet again loose in the holder. WWest, thank you I will try to find a new block, I assume our panels have three blocks so the first one is the one I need or can just the holder be replaced. I will search it out. Hell, or go ghetto and do the outrigger, I would if it can handle the heat??? |
I ended up going to Morro Bay last weekend, so no worky on my ac. Hopefully I will get it working and observe my fuse temp. I wonder how many amps you're pulling and if it'll melt again.
Draco, why don't you simply put an amp meter on the evap motor lead?
I went ahead and ordered a New Block only $21 plus 2 new rails $1.90 each. Well, we will see. |
Keep it in your tool box. You'll need it another day. |
Shoot, I've three or four multimeters. I'll let you borrow one - put it in the mail.
Thank you Gentlemen, I will visit the Electric Supply Store. like said I may need later :D
| All times are GMT -8. The time now is 01:29 AM. |
