-   -   Weird 911 Handling Problem, Gurus needed! (http://forums.pelicanparts.com/porsche-911-technical-forum/611159-weird-911-handling-problem-gurus-needed.html)
AZAirCooled 05-29-2011 09:28 AM
Gurus,
Wierd 911 Handling Problem:
Changing lanes or lines at highway speeds the car starts to weave back and forth. It is borderline unsafe at highway speeds while driving normal. But it is a bit scary at high speed driving. This problem started after making several suspension changes at once.
The following changes were made at the same time in a Porsche shop:
1. Lowered the car.
2. Replaced 23mm rear torsion bars with used 25mm torsion bars.
3. Replace stock non-adjustable spring plates with worn out bushings with 911SC adjustable springe plates with new elephant racing rubber bushings.
4. Installed new Bilstein HD's all around (rear right was blown).
5. Installed bump steer spacers on steering rack.
6. Replaced rear 195/55/15 Yokohama S. Drive tires on 7X15 wheels with new 205/55/15 Yokohama S. Drive tires.
7. Aligned car and added a little more rake.
8. I set tire presures set at 37 psi front and 32 psi rear.
Additional technical relating to the suspension data:
1. The car is a 1976 911S with 169K miles, very well maintained.
2. The front wheels are 6X15 with medium wear 195/55/15 Yokohama S. Drives
3. The steering rack was replaced a year or two back with a low mileage one in excellent condition.
4. The car has turbo tie rods.
5. 60 lbs have been removed from rear of the car.
6. Maybe 350 miles on new rear tires.
7. Previously have run these yoks 195s on 6x15 wheels all around, no problems. Was running 195s all around on 6x15 front and 7x15 rear wheel before suspension upgrades without the problem.
8. Sway bars - 20mm front/18mm rear
9. Front torsion bar is stock 19mm.
Correction action/analysis to date:
1. Took car back to Porsche shop for planned alignment check and problem analysis.
2. Rechecked alignment - it was ok.
3. Checked tire pressure. Changed to 41psi front, 44psi rear.
4. Inspected all bushings. All ok. Only sway bar bushings had small cracks.
4. Took road test, shop owner driving, yep, still weaving.
5. Replaced rear wheels and tires with 205/55/15 Goodyear F1s on Fuchs off the front of a 911 Turbo (they looked like 7x15s).
6. Took another road test, we both drove, the weaving was gone!?!
7. If I hadn't seen it and felt it, I would not have believed it was my new rear tires!
So it has to be the new rear tires, right? But why?
a. Bad tire(s)?
b. Sidewall stiffness change from 195 to 205 in rear?
c. These yoks don't play well with staggered sizes?
d. These yoks don't like the suspension set up?
What is the best course of corrective action? What is the best tire/wheel size set up? I use this car for the street, in town and road trips. I do not intend to race again (well maybe a little racing lite). I have been setting up the car for livable, but high-performace, street driving. Of course I do not want to waste money.
Some options:
1. Go back to 195/55/15s on 7x15 in the rear and 195/55/15 on 6x15 front(low$)
2. Go to 195/55/15 on 7x15 all around(low$).
3. Fight with tire store for replacement of 205/55/15 rear yoks(no$, maybe).
3. Go with different 205/55/15 tires on 7x15s all around (bigger$).
4. Buy 7x16 Fuchs, 195/50/16 front and rear tires (biggest$).
5. Buy 7x16 Fuchs, 195/50/16 front and 205/50/16 rear tires (biggest$).
6. Buy 7x16 Fuchs and 205/50/16 all around (biggest$).
I have 2 each extra 6x15 and 7x15 wheels and 2 195/55/15 yoks availble. I was going for the staggered look/feel of a Carrera 3.0 and the best handling set up. I am willing to go to 7x15 all around but I was concerned about reducing understeer and making the car less neutral and posibably too much oversteer for aggresive street driving with a small margin of safety. I do not want to go lower profile than 195/55/15 or 205/55/15 as highway rpms are as high as I am willing to accept.
I would appreciate the thoughts and experiences of you 911 suspension gurus out there. I am a long time car guy with a little racing experience but reletively new to rear engine handling 911's. But I have never heard of this problem before or a new name brand high performance tire being bad.
Thanks, Bob
Targalid 05-29-2011 10:46 AM
I have experienced squirrely handling for two reasons: low tire inflation and improper alignment. You seem to have covered both of these areas so I am stumped. It sounds like you have poured a lot of money into your suspension upgrades. I would still suspect alignment. Perhaps your alignment shop did not compensate for your suspension upgrades or compensated for something they should have not.
Flieger 05-29-2011 11:03 AM
The tires that solved the problem had some wear on them, right?
New tires have deeper tread = more tread squirm. With your worn fronts, combined with the extra rear roll stiffness you added with the stiffer rear torsion bars, the new rears will make the rear end loose. When they have some miles on them and they get "scrubbed in"- that is, the mold release wears off and the tread starts to get down to the good rubber and shorter tread, the handling should improve.
This is why it is best to replace tires as a set when handling matters.
AZAirCooled 05-29-2011 11:26 AM
Thanks for the input Flieger.
I have experienced "tread squirm" on sports cars after 4 new tires before. But never the weaving. I may have all ways replaced all 4 tires though. These new rears have a couple hundred miles on them already. Plus they were the same mfg/model. I had thought about new tire "tread squirm", but did not think it would have such a profound effect (still my first 911 though).
Do you think new tires up front (195 or 205) would eliminate the weaving? Or are you suggesting my 911 will be unsafe at high speeds with this set up after every set of new tires?
I originally wanted 24mm rears so the set up would be the same as an 78 SC but they were not readily available used. The current set up is the same as an 84-89 Carrera. But I know my car is few hundred pounds lighter.
I do like the thought of not have to spend more money. I think I will go out and do a little rear tire spinning today and tommorrow to see if the weaving gets less. I have plenty of torque with the 3.0 and smaller tires :)
I was thinking about trying to get a Yokohama manufacturers representative involved.
AZAirCooled 05-29-2011 11:33 AM
Thanks for the input Targalid.
Alignment was my first thought. The weaving reminded me of when I was younger and autocrossed an 86 MR2. I would kick the camber to full negative on on four corners the night before a race. I would drive it like that to the event and it would not want to drive dead straigh on the freeway for twitching/weaving! But it was a blast at the track!
But remember the weaving went away with different rear tires. Flieger may be on to something. If so, this 911 set up is VERY sensative!
Flieger 05-29-2011 11:36 AM
Well, trying to diagnose the cause of "weaving" with only that word and not driving the car is hard to do. ;)
I was theorizing that the weaving was just you experiencing the differential of tread squirm between the front and rear tires. If you put new tires on all corners, the car would likely feel a bit like driving in rain but not exhibit so much yaw instability- just a more vague connection to the road.
Flieger 05-29-2011 11:37 AM
About the 911 being especially sensitive to setup;
like I said, changing the roll stiffness distribution towards the rear will only amplify any other yaw instability.
wildcat077 05-29-2011 11:45 AM
Why is your tire pressure set so high ?
I see you started at 37 psi front and 32 psi rear then you went to 41 psi front and 44 psi rear ...
Normal settings are 29-30 front and 34-35 rear depending on your preference.
I start at 32 psi front and 34 rear and aim for 36 front and 38 rear max during my track sessions and bleed accordingly depending on the conditions,anything above that and you lose traction !
For the street i run at 29-34 in order to get even tire wear.
Cheers!
Phil
johnsjmc 05-29-2011 12:39 PM
What alignment specs are you using? I also question the high tire pressures. It appears your tires are same brand .Has the internal construction of the tires been upgraded or changed ie different belt fabric or number of belts between the time the fronts were manufactured and the new rears? I have seen similar yaw when using tires from different manufacturers F/R but not so much from used /new same type.
kodioneill 05-29-2011 12:43 PM
I agree tire pressures too high.
s_morrison57 05-29-2011 12:46 PM
A low degree of Castor will cause a car to weave, check the castor, don't know of hand what it should be but has to be over 5-6* to stop weave.
Trackrash 05-29-2011 01:25 PM
I had a problem similar to what you described after some suspension mods and going to Bridgstone S03s in the rear.
I chased my problem for a year or so. As the tires wore in it improved but did not totally go away. It was mainly evident on the freeway with GROOVED pavement.
I got a second set of tires and wheels with Toyo RA-1s and NO more problem. My S03s are for sale.
Targa Time 05-29-2011 01:47 PM
I had a problem similar to yours after replacing the rear suspension. Turns out that even after tightening the axel nuts to 200ft/lbs and installing a cotter pin, the axle nut loosened up just enough to cause handling problems like yours. Easy enough to check. A fellow PCAer has a wrench just special for that nut. It's about 4' long.
mholbrook38 05-29-2011 01:51 PM
I like about 5 pounds more tire pressure in rear than in front.
johnsjmc 05-29-2011 01:56 PM
If I were to guess I think you need a little more toe in on the rear. It wears tires more quickly but acts to keep the rear planted. Would like to know the front rear alignment settings to offer an opinion re alignment instead of a guess. Also I prefer tire pressure around 32F and 36R cold for street driven normal loads.
80-911SC 05-29-2011 03:19 PM
same as wildcats ????
why is your pressure so high ??? i run my front 225 17 at 28 and my 245 17 rear at 31
yours are set almost as high as my pickups tires ...
your rear should be higher psi than the front ... your weight is in the butt area ...
Just because it says max psi on the side wall does not mean you pump them to the max ...
I'd try lowering that a bit first ........
mrk_d 05-29-2011 03:33 PM
Definitely sounds like tire pressure is contributing to this sensation. After buying my car and driving it for a few weeks, I decided that I should check my pressures. All 4 were at 51 PSI (!!!), the max indicated on my tires. Lowering them to recommended pressure helped handling a ton and made it drive so much more comfortably on uneven pavement.
dshepp806 05-29-2011 03:40 PM
Out of all the cars I've driven with NEW tires,....the 911 has terrrible sqirm,..and will require hundreds of miles before she locks down. I hope that's all this is,..in the end.
I stay with 29/F and 36/R (COLD)
Doyle
wildcat077 05-29-2011 04:03 PM
Bob,
PM me your email address and i'll forward you my alignment spec sheet which was done by a Porsche race shop a few weeks ago.It's a compromise between street and track and it really made a difference to my car handling wise ...
I have about a dozen track days lined up this season and this setup works well for me !
Cheers !
Phil
AZAirCooled 05-29-2011 04:49 PM
Thanks everybody! That is a lot of good feedback.
I used to run 29psi front and 34psi or 30/35 (whichever is in the owners manual) before the new rear tires and suspension mods and I had no weave. I just realized I raised them per the shop recommendation when the car was lowered and the new rear tires added. I can't remember if they checked the tire pressure on the Goodyears that did not weave. I will lower them before I drive home on the freeway today. I will post the results.
Wow. Tire squirm differential front to rear causing instability on the freeway. I have a lot more to learn about 911's.
Steve@Rennsport 05-29-2011 04:58 PM
JMHO,.....
Based on a few years of driving 911's, I've learned (through the same experience) that I always replace tires in sets, never just a pair.
With very rare exception for me, installing new tires at one end or the other results in the same, somewhat frightening experiences so its always a four tire change.
Remember, starting tire pressures mirror the weight distribution of the car so one should always have staggered pressures with the higher pressures in the rear.
DanielDudley 05-29-2011 04:59 PM
My wife's Saab just came out of the shop, and it was all over the road. Tires at 42 PSI. Dropped them to 35, and all is well.
The tires were topped up by a Saab technician. It says 35 F 35 R right in the door.
wildcat077 05-29-2011 05:05 PM
Here's a good base alignment setup for the guys who PM'd me for the specs ... You could go more agressive but if you drive your car on the street your tires won't last long ...
Cheers!
Phil
http://forums.pelicanparts.com/uploa...1306713892.jpg
rusnak 05-29-2011 05:20 PM
I kinda skipped through this thread, sorry. Did anyone say to check the rear wheel bearing wear/ adjustment? Push sideways on the rear of the car with your shin while watching the wheel rim for movement.
RSTarga 05-29-2011 05:45 PM
go back to 29/34 tire pressure. The settings you have used are both high and should always be 5 or 6 pounds higher in the rear, except on 964's and later. I have, at times bought new rears and left the original fronts. It may take a few hundred miles for the rear sidewalls to loosen up a bit, in the meantime the car may get that twitchy feeling especially under braking. One of the reasons you should not put different brand or type of tires on the car.
crashmy911 05-29-2011 06:23 PM
You need to run alot less pressure in the front. 37 pounds is way too much.
Flieger 05-29-2011 07:10 PM
I would also agree to lower the tire pressures, but I would think so long as the percent difference stayed the same (higher in rear) the handling would be similar as far as yaw stability, just with reduced grip. More of a 4 wheel drift than swapping ends.
I run something like 28 front and 32 rear warm, they are all less cold but the rear also gets closer to the front pressure, meaning the rears heat up more than the fronts.
moneymanager 05-29-2011 08:20 PM
I'm with Steve. Running different tires front and rear was a disaster for me the only time I tried it. Car felt like it had a gigantic case of oversteer... you'd move the steering wheel an inch and the back end would step out sharply. Scary. Borrow four identical tires/wheels from someone, inflate them correctly, and I think your problem will go away.
jpnovak 05-30-2011 05:39 AM
Was the car corner balanced after replacing the rear torsion bar and spring plates?
AZAirCooled 05-30-2011 08:13 AM
Thanks to everyone for the feedback! My 911 keeps getting better! I love the Pelican Parts forums!
Last evening on the way home I changed the air pressure to approximately(gas station stick gauge) 29/34. WOW! The weird "weaving" went away almost completely! I can barely feel the "weave" but it is no longer scary/unsafe. Today I will check/set the tire pressures completely cold with my digital gauge to 29psi front and 34psi rear. Man I feel dumb as this is what I used to keep the 195s at (per the owners manual).
Based on the great feedback from my fellow Pelican enthusiasts, the small remaining effect may be the "tire squirm" differential between the broke in front 195/55/15 Yokohama S Drives and the new rear 205/55/15 Yokohama S Drives. So I think I will just drive it for a while to see if it goes away as the new rear tires break in.
There has been such a great response to my problem post that I would like to ask those following this thread to weigh in on what you feel would be my best my final wheel/tire set up.
As stated, the car now has broke in 195/55/15s Yokohama S Drives on 6x15 Fuchs up front and new Yokohama S Drive 205/55/15s on 7x15 Fake Fuchs on the rear. This gives me a 1976 Carrera 3.0 tribute sans the rear flares, 185s front/215s on the rear, a little weight, and 20hp (coming with SSIs). Plus I thought 195s up front would give a little less oversteer for additional safety on the street. I was hoping with upgrades, updates, and backdates to match or exceed the performance envelope of a Carrera 3.0.
In the garage I have 2 additional 6x15 wheels, 7x15 wheels, and 195/55/15 matching Yoks.
With minimal money/effort I could change to:
1. 205/55/15 Yoks on 7x15 all around.
2. 195/55/15 Yoks on 7x15 all around.
3. 195//55/15 Yoks on 7x15 front and 205/55/15 Yoks on 7x15 rear.
Long term options are:
1. 195/50/16s on 7x16 all around.
2. 195/50/16s on 6x16 front and 205/50/16 on 7x16 rear.
3. 205/50/16 on 7x16s all around.
Specifically, I would like feedback on staggered tire/wheel combos verses the same sizes all around on 911's. It seems that smaller tires up front would provide some understeer on a car that wants to oversteer. This is my first rear engined car. I have always driven hard on occasion and am accustomed to a predictable, controllable, 4 wheel drift at a cars limit of adhesion. I have heard stories of 911s handling great until thier limit of adhesion when the rear would suddenly come around. I would imagine this to be uncool on a mountain road if true.
P.S. The car received a four wheel alignment but not corner balancing. Rear fenders are rolled. Photos are before lowering.
Thanks again,
Bob
RoninLB 05-30-2011 10:20 AM
I think you're scrambling a narrow body by seeking what it looks like over what should be done
use 4 7x15 Fuchs and 4 205/55x15 tires [roll fender lips] [7s should give you a stiffer sidewall]
set ride height to so called "Euro Height" with rake set at 1 deg
install Carrera front spoiler [worry about tail later]
air psi 29/34 or 29/35
it should stick to the road like glue at 75 mph and be just high enough to not mash your spoiler going into gas stations etc. It should be easy and predictable to drive
------ that's just my routine
1QuickS 05-30-2011 11:03 AM
I'd look closely at rear toe settings. When the rear suspension arm rises (bump or compression due to weight change during lane change) the wheel will toe-out. This toe-out is a steering input at the rear of the car which if the toe setting isn't toed-in enough will cause the rear to step out. When you correct the swerve the opposite happens to the other side due to weight transfer which will set up a divergent oscillation, to a point.
Trailing-throttle oversteer happens when the rubber bushes deflect causing the loaded outside rear wheel to toe-out PLUS the toe-out from suspension deflection and on the early cars with small tires all the weigh transfer would overload the tire. Larger tires, stiffer bushings and large toe-in settings tamed this issue somewhat.
SAH 05-30-2011 03:02 PM
Yes tire pressures are to high. If your problem went away with the change to the 205/55 assemblies than I would strongly recommend looking at what the rear camber is. Had an 86 911 with A008's lowered and alignied and drove great. Customer went and installed Dunlop D40 tires and it was scary in the rear like it had rear steering! Ended up adjusting camber back to .50 to .75 neg and problem solved. Not all tires are created equal when it comes to alignment specs.
AZAirCooled 06-02-2011 01:13 PM
Ok, I think the weird handling described above is almost completely gone! I set the front tires to 29psi and the rears to 34psi, like the owners manual instructs. I can't believe the difference in tire pressure made the car unsafe in a straight line at high speed.
There is a very small sway left changing lanes/lines abrubtly at high speed. Barely noticable. I will let the rear tires wear in more before I make any other changes.
