APKhaos's Avatar
Racewear Rodbolts
Since dropping my 3.2 on the weekend, I've decided to go at least as deep as the rod bearings. Given that the stock rod bolts are a weak point, Racewear bolts will go in.
Anyone have a source for Racewear rodbolts? Thanx!
Its kinda odd what you find when you go in to fix something. When the engine and trans came out, I did what everyone probably does....poked around into all those little spots that we never see when the engine is installed.
Took a close look at the throwout race, and found that it had almost half an inch of axial play - it was moving around the centerline freely, where the pressure plate fingers should have been holding it tight. Whats more, it made the very same hollow rattling sound that I've been hearing at idle with the clutch released since I bought the car a year ago. My wrench thought this was spendy 915 bearings, although he said he had never heard them quite this loud in a box that was otherwise operating fine. It looks like the problem is the pressure plate & TO, which is great news!
I'm enjoying this way too much, but it looks like I'll miss the first DE of the season - there's no way this will be back together by 15 March!
Tony K
'89 944T
944 SuperCup Champ 2004 & 2005
'85 Carrera - Sold [sob]
TrackVision
944Cup
The 999 Site
Old 02-28-2002, 06:23 PM
Wink
Did you try Pelican Parts. Probably the best prices around. If their not , tell the parts man.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-28-2002, 07:05 PM
APKhaos's Avatar
Ouch Ron!
Pelican was the FIRST place I looked - no luck on the site, but will call as well. Like most of us on this board, Pelican is the preferred vendor - got the receipts to prove it.
Guess I thought/think that these might be single source items. Could be wrong. Eager to learn.
Tony K
'89 944T
TrackVision
944Cup
The 999 Site
Old 02-28-2002, 07:26 PM
Wink
#2 on the hit parade is EBS/Engine Builders Supply 1-800-462-3774 www.ebsracing.com is where I have bought plenty of things. Another dealer once told me to use them for new 2.7 RS pistons because they are sometimes unable to compete with on some items. I did buy Racerware from them
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-28-2002, 07:39 PM
cwood
Guest
Posts: n/a
For the 3.2L
ARP 204-6005 Porsche 9mm rod bolts
$184.44 From Summit including shipping
Summit part # ARP-204-6005
Old 02-28-2002, 11:45 PM
RLJ RLJ is offline
Senior Registered User
TheSummit price is cheaper than ARP's price to small shops.
Randy Jones
1971 911 w/ ARP rod bolts.
Old 03-01-2002, 12:09 AM
