-   -   weird behaviour and A/c removal (http://forums.pelicanparts.com/porsche-911-technical-forum/6116-weird-behaviour-c-removal.html)
John Brandt 07-16-2001 08:57 AM
I did a valve adjustment and removed my non-functioning comressor and condenser at the same time. The car is running right,(perhaps a wee bit loud) and I even had a DE weekend afterward. the Idle is higher now most of the time. What caused this? Less drag on the motor or did I botch the valve adjustment?
john walker's workshop 07-16-2001 01:52 PM
the A/C freewheels when it's off, so that wouldn't be it. perhaps the engine is running more efficiently now that you've done the valves. nice work.
89911 07-16-2001 05:59 PM
The drag on the engine from the AC has got improve a bit, could explain the higher idle.
