85911's Avatar
HVAC System
I am working on my heater system on my 85 911. All blowers have been either replaced or refurbished. I checked the fuses in the engine compartment and recorded the following:
#1. 16 amp fuse- blown
#2. 25 amp fuse- blown
#3. 16 amp fuse- good.
The Owner's Manual does not identify location and calls for the following:
Rear window defogger, rear window wiper return (which I don't have) 25 amp
Heater fan 25 amp
Relay for heater fan 5 amp
My Porsche manual states the following:
#1. Heater blower relay 16
#2. Heater blower 25
#3. Defogger, rear window wiper 25.
Attached is a picture with the bad fuses removed and the positions are 1 on the bottom, 3 on top.
I assume the Owner's Manual is wrong and that I should follow the Porsche manual.
I'm wondering if there was a 16 amp fuse in position #3 because I don't have a rear wiper.
1985 911 Carrera Targa, 2011 911 Carrera S 997.2, 1951 Harley Davidson Panhead Chopper, 1957 Harley Davidson Panhead- stock, 1972 Yamaha 250 DT-1(sold), 1959 Austin Healey (Bug Eye) Sprite- sold, 1959 Austin Healey (Bug Eye) Sprite- sold, 1960 Austin Healey (Bug Eye) Sprite- sold
Old 02-16-2015, 01:41 PM
wwest's Avatar
Some one has reverse wired your engine compartment fuse block?
Top to bottom for my '88 Carrera engine compartment fuse block.
1. Cabin heater control relay power.. Controls footwell blower power, provided cabin heater blower is pulling maximum current flow.
2. Cabin heater blower power, blower in engine compartment.
3. Rear window defrost grid power.
Footwell blowers stop if I remove #1
Cabin heat blower stop if I remove #2, as does footwell blowers, DUH!
Didn't test #3
Old 02-16-2015, 03:41 PM
Check the Bentley. I believe different years were wired slightly differently.
Old 02-16-2015, 04:23 PM
