I would rather be driving
the truth? #2: 915 in 901 space
Another question for the board. the drivetrain for the 71 project car is from a 78 SC(RIP). I hear that the tunnel has to be modified to fit the 915 into the space where a 901 used to reside. Is this true or false?
If true? what has to be modified? Is the space too narrow? shallow? short? Please shed some light on the underside of my car.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Home of the Whopper
Jamie!
How's the project going? If you need a hand, let me know. Never put a 915 in an early car, but from what I've heard you need to hammer a little more room. Test fit and then hammer away! Have fun! BK |
Jamie,
I recently completed a 3.3 Turbo/915 tranny install in my '70. You'll need to beat up the tunnel slightly for correct fit. Good luck.
1969 911E Albert Blue 1970 911E Iris Blue 1970 911T Signal Orange 1972 911T Gold Metallic 1981 930 Arctic Blue 1981 930 BB Auto(on ship) 1987 930 Cassis Red Met 1996 993TT Black 2007 997TT Cobalt 2017 991 Turbo Cab |
Here's a hint. Temporarily remove the front cover from the transaxle and mount it onto trans. mount (don't forget to drain the oil first). This assembly is a little lighter to handle to see where you have to smack the tunnel. Use a large ball peen hammer. Protect the enlarged area with some undercoat or paint before reinstalling the drivetrain.
Sherwood Lee http://members.rennlist.org/911pcars www.seine.systems.com |
I had heard the same thing but i had none of these problems. Mine fit right in, and my 915 has the gear oil cooler off of the side too.
Paul
My ignition is retarded. |
Thanks for all the responses. I had read there was a problem in the Project 911S from European Car. I have not made it to that part of the project yet. Removing the cover and front mount is a good idea. Sure beats lifting the tranny.
Paul, I guess the "individuality" of these cars will determine how much difficulty I find. thanks again for all your help.
JAMIE,
I EMAILED YOU A WHILE BACK, LET ME KNOW WHEN YOU ARE GOING TO BE IN THE GREENSBOR AREA AGAIN, I WOULD LOVE TO SEE YOUR CAR. PAUL
