-   -   Turn signals (http://forums.pelicanparts.com/porsche-911-technical-forum/612259-turn-signals.html)
Reifle 06-04-2011 11:38 AM
Turn signals
I have a '77 911 which is in very good condition - more interior cosmetic issues really. I read a recent post where the gauges were sent out and fully reconditioned. This is one of my future plans - possibly this winter. My question - the turn indicator in the speedo - when I use the turn signal both lights - left and right - come on. Is this due to the age and close proximity of the indicator or can this be changed when the gauge is reconditioned?
jnewman 06-04-2011 02:18 PM
I had this problem in my Porsche and BMW. It is indicating a blown bulb or electrical fault. Have someone stand behind the car and tell you what the lights are doing while you activate the turn signals, brakes, etc.
Reifle 06-04-2011 06:56 PM
The lights work outside - it's the one in the speedo where it shows both direction - just want to know if this is normal.
DRACO A5OG 06-04-2011 07:37 PM
No not normal, check your wiring if good then send it back to shop to correct it
Porboynz 06-04-2011 10:26 PM
Probably a missing/poor earth connection on the speedo, they are rubber mounted so if the earth is poor then the return path is through the other light bulb. Simple to run a temporary earth with a jumper cable or similar.
