911 starting issue
Hi all
I am currently having an issue with starting my 1974 911(with 3.0l SC engine). When I turn the ignition to the ON position, the starter motor starts without me moving the ignition switch to the starting position.
Now I have just replaced the electrical part of the ignition switch with a new item (supplied from our sponsor), but this has not solved the issue.
Any ideas?
Thanks in advance.
Old 06-03-2011, 04:58 AM
twistoffat's Avatar
I´m no expert when is comes to electrics but is the lock body properly alligned with the ignition switch?
Old 06-03-2011, 06:04 AM
Originally Posted by brown911 View Post
Hi all
Any ideas?
Thanks in advance.
First question, was there a fuel pump relay added to your car? The 74 did not have a fuel pump relay as did the later cars so if one was added to allow for the air flow sensor of the 3.0, it may have been wired incorrectly and you are getting electrical "feed back" to the starter circuit.
You did not mention if this was a new problem or if it just began with the installation of the 3.0. Also, we don't know what wiring was changed to adapt to the new engine. If no relay was added and this is a new problem, it shouldn't be too hard to find as the circuit from the ignition to the solenoid is direct on a 74 (yellow wire.) You might try unplugging the 5-pin connector from the ignition switch and plugging in the new electrical part, then turn it with a screw driver to see if it works correctly. Report back any additional information.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 06-04-2011, 08:38 AM
Thanks for the advice, this is a new problem, I have had many years of trouble free running with the 3.0 litre, and yes a fuel pump relay was added when the 3.0 litre was installed. Looks like I will need to trace the wiring.
Thanks again.
Old 06-04-2011, 04:59 PM
I disconnected the fuel pump relay and the car turned over as normal, so definantly fuel pump relay related.
Old 06-04-2011, 06:21 PM
Problem solved, replaced fuel pump relay and all is well.
Old 06-04-2011, 09:58 PM
