Clutch Cable - Strange sympton
I tried to adjust my clutch cable. I tightened the adjusting nut on the cable and the cluctch pedal looked liked it was in the right position. I pulled on the pedal with my hand and it had about an inch of play. Then I stepped on the clutch pedal and it didnt want to move, then I hear a pop and the pedal drops down a few inches and stays there. I tried tightenening the cable more, and the same thing happened. Does this sound like a cable problem or something bigger?
Royal Purple/Lilac, Signal Orange, Guards Red |
Mine did something similar when the helper spring wasnt installed correctly but it doesnt appear yours uses a helper(omega) spring. So Ill let the experts chime in...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Remove the cable from the tranny, pull on cable to see if it broke in the tunnel (might want to remove it to check it out). If not, remove floor board and check to see if spring broke at cluster. If not get back under tranny grab lever to see if it moves alot, if so the fork might have broke inside the tranny.
P.S. That is one clean looking tranny/motor.
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 05-31-2011 at 09:28 AM.. |
I'll remove the cable tonight and see what I see. I treid moving the lever and it doesnt move, only wiggles a little bit. I am just getting the engine and tranny back in for the first time since rebuild. Lots of little things to adjust, I was worried that I put the fork on incorrectly and would have to drop the transmission.
Thanks!
P.S. I noticed the custom mount for the clutch cable, what year car and tranny is this, could you also have the wrong clutch cable? Oops, its a 72-best damn year porsche ever made, is it a 72 tranny? Well maybe not tranny wise in regards to the seal.
72 911 Although it is done at the moment, it will never be finished. Last edited by tobluforu; 05-31-2011 at 10:47 AM.. |
Something at the pedal end. Either bushings or the cable clevis.
The tranny is a 72, The custom mount for the clutch cable is because the corner of the tranny where the cable passes through was broken off at some point, so instead of having a hole to pass the cable through I had a 3/4 circle. The bracket is to make sure that the cable remains secured.
To fix my problem, I removed the arm and turned it towards the back of the catr by one spline tooth. Also, with the cable, I had the metal cap on the end of the cable housing on the side of the bracket closest to the front of the car. I moved it so that the rubber cable housing passed through the hole, and the metal cap was on the side closer to the back of the car. I pushed the clutch to the floor and it went down and came back without issue. Hopefully, thats it, I wont know til I get the car buttoned up and get to take a drive.
72 911 Although it is done at the moment, it will never be finished. |
