-   -   Engine Misfire under load. 74 2.7 (http://forums.pelicanparts.com/porsche-911-technical-forum/612366-engine-misfire-under-load-74-2-7-a.html)
typeonemb 06-05-2011 09:49 AM
My 911 developed a misfire after hitting a large unmarked pot hole on a BC classic car tour.
I discovered that the distributor cap was unclipped on one side and on a slight slant. Re-securing the cap did not cure the problem. I limped with miss back to civilization for about 100kms. I replaced the cap and rotor with the only jobber parts that I could get on a Sunday and it ran fine for about 500kms including a climb over a large mountain pass.
The next morning the miss had returned and despite much fiddling around on the side of the road, I ended up driving the last 400kms back to Calgary with the engine miss.
Since my return, I have done the following:
-Replaced the cap and rotor with the correct bosch items
-Replaced all spark plugs, gapped slightly wider than stock
-checked that all plugs are firing
-checked timing
-checked firing order.
-checked mixture via "field test" method.
Now the car idles fine and runs okay under light throttle but misses under load.
Other notable items
- Pertonix ignitor II installed last year
- Pertronix flame thrower coil, last year
- New Behr ignition wires last year
- original factory CDI box
- the battery is marginal and should be replaced. It starts the car fine if left on a battery minder but will need a boost if the car sits with out one after a couple of weeks.
Is it possible that the marginal battery is causing the miss under load? The Alternator is bosch unit in good shape. I seem to remember reading that the Petronix unit will not work properly under certain voltages.
I am open to suggestions.
Cheers,
Mike Bennett
j911brick 07-08-2011 12:55 AM
Its possible the CD unit was damaged.
