-   -   Turn signal "flasher" where is it? (http://forums.pelicanparts.com/porsche-911-technical-forum/6124-turn-signal-flasher-where.html)
joehahn 07-16-2001 09:44 AM
Finally tackling the peculiar blinker problem (varies from 1 working to both in unison, to no action at all). I have read all the archived posts and am pretty sure I know what procedure to use (check grounds, contact points, etc) but I am wondering about the "flasher". I thought that was a generic term for the blinker itself but many people refer to a bad flasher. Does this mean a "flasher relay?" If so, where is it? How do I check it?
Thanks,
Joe 68L
campbellcj 07-16-2001 09:52 AM
I'm not sure about your early 68 car, cuz quite a few things are a little different (or a lot different), but on my 70 it's a little rectangular relay box behind the dash gauge panel. It's behind the fuel/oil combo gauge (left side) IIRC.
They do go bad. Unfortunately the part is around $35, but it's an easy fix.
Chris C.
Planter91C2 07-16-2001 10:51 AM
$35 for a flasher. whoa. i would try to modify a $1.50 flasher. they are a very simple device. i'm sure the contacts could be modified to fit the port.
Daryl 964 Targa
joehahn 07-16-2001 10:59 AM
...what's it look like?
campbellcj 07-16-2001 08:21 PM
I used to have a good picture of one (in the car) but I can't find it...there's no pic on the Pelican catalog either.
The flasher relay is just a small rectangular box -- probably silver colored (metal) if original or black plastic if newer -- about the size of a "D" flashlight battery or so.
Easy way to find it is by sound (if it works at all) - the clicking sound when your blinkers are on comes from the relay. Follow the sound.
Chris C.
[This message has been edited by campbellcj (edited 07-16-2001).]
rattlsnak 07-16-2001 08:33 PM
On my '66 model, both the turn signal and flasher relays were mounted under the footboard, right above the brake pedal.
Marc
