-   -   broken drop link (http://forums.pelicanparts.com/porsche-911-technical-forum/612592-broken-drop-link.html)
Moke81 06-06-2011 05:57 PM
broken drop link
I was installing the cat. to take it in for smog and noticed the drop link broke at the bottom. How hard to replace it?
Barclay
_______________
1981SC Coupe
DRACO A5OG 06-06-2011 05:58 PM
Easy, two bolts, 19MM, 61 ft lbs, I would replace in paiirs
Leave the car on the ground, raising will pre-load them or raide the car and use a second jack to raise the trailing arm to the link, much more difficult and dangerous.
Moke81 06-06-2011 06:06 PM
Can I get to them with car on the ground?
Tigerrat 06-06-2011 06:16 PM
Sounds like some ramps would do the trick?
DRACO A5OG 06-06-2011 07:29 PM
Yes, on the ground. If you are too large then ramps would help to gain better access but not really needed in my case.
Depending if your car is stock or upgraded to thicker sways, you may need a Long Philips to manuveur the drop link and maybe a wood clamps to keep the link in place.
To break the bolts/nuts loose use a cheater bar.
