Left side Fuel Rail removal?
Hello All,
I am replacing my injectors, and have successfully r&r'd the right 3, but have not been able to get the left side fuel rail off..... not that I tried too hard, I stopped for supper before I tried too many things.
I am thinking I can simply loosen (but not remove) a single fuel line cheap software buy cheap software connection to the rail, and pivot the whole deal up, just enough to get the rear injector out?
Thanks!!
Old 06-24-2011, 11:50 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Oh boy, fun fun fun.
You need to remove the nuts in the back, tight as heck then it will be smooth from there on until you put the rear nuts back on. I recall I used two wrenches.
Caution, make sure when you put the new injectors on not to pinch those Orings, I tore one and it leaked like crazy. Wouldn't you know it the driver side
Oh and Welcome aboard!
Any Pics?
'85 Carrera Targa
PCA/POC
Old 06-24-2011, 11:54 PM
6 cylinder symphony
Like Draco said - you need two wrenches. I used flare nut wrenches. Be careful not to bend anything.
Mine were super tight, and it took a ton of effort. But - once undone, just lift the whole rail out. You'll need the room anyway.
Good Luck.
Ken
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 06-25-2011, 05:32 AM
Suggest a little liquid soap on the injector o rings to get the injectors back in the fuel rail and manifold.
Old 06-25-2011, 05:40 AM
