Head light switch
On this 76 911 I am putting in a new turn signal indicator. I have dropped the head light switch in order to make it easier to connect the wires from the new turn switch. When I pulled it from the back of the dash there are two wires I believe got disconnected. I have done nothing yet with the wiring as I want to go slowly and not get anything mismatched.
I would like to know if the wire, in the picture, with brass, L connector (white with black strip wire) and the short wire, (in the middle of the pic.) belong together and need to be connected to the bare pole on the switch #56?
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster Last edited by bcgreen; 05-04-2020 at 12:34 PM.. |
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster |
just read the colors;-) how otherwise you would like to be helped???
1st picture is your guide... ivan
