-   -   Optimoly HT equivalent ? (http://forums.pelicanparts.com/porsche-911-technical-forum/613366-optimoly-ht-equivalent.html)
Inniswhe 06-10-2011 06:10 PM
I am replacing my clutch and the sachs kit I bought had a small packet of what look like lube in the kit. I assume it is the shaft antiseize compound refered to as Optimoly HT in the Bentley manual .
At any rate I lost the packet ane need a local replacement to get my tranny back in this weekend.
I was going to use the permatex copper antiseize ( sparingly) as a substitute . Does anyone know if I would be making a big mistake to use this product ?? Is it thick enough to stay on the shaft ?
Where I live , the Optimoly HT is probably at least week or two away and want to get my car back together asap.
304065 06-10-2011 06:50 PM
Optimoly HT is silver antiseize, very similar properties
I use Lubro Moly copper antiseize on everything
the Permatex is probably just fine
But if you must source a local version, try and find some silver antiseize.
Optimoly HT is made by Castrol, you can download their datasheet to compare it to whatever you find.
rusnak 06-10-2011 07:35 PM
the little packet contains high temperature grease. You can get a tube of equivalent grease from another vendor who also has a forum and sells racing parts in souther Calif . It has to be shipped ground, so it takes forever to arrive.
Quicksilver 06-12-2011 02:59 AM
I use Bosch distributor grease instead of the Optimoly HT. You should be able to find it at a VW shop.
Inniswhe 06-12-2011 07:46 AM
Before seeing the note about the bosch grease I went ahead and put some permatex copper antiseize on the splines.did I make a major mistake?
I can dissassemble if necessary.
Bill Verburg 06-12-2011 08:03 AM
Optimoly HT is a copper based high temp lube
Optimoly HT
Bill Verburg 06-12-2011 08:04 AM
Permatex Copper Anti-Seize is an equivalent product to OptimolyHT.
Inniswhe 06-12-2011 11:37 AM
Thanks bill
Steve@Rennsport 06-12-2011 11:42 AM
Well done!!!! You did just fine. :)
Bosch distributor grease is not the correct product for this application.
porschenut 06-17-2011 10:53 AM
The factory manuals also call for Optimoly TA in some applications. Does Permatex have an equivalent for that one too?
G50-Love 06-17-2011 01:49 PM
I wonder if you can just use copper antiseize everywhere they call for silver antiseize?
pmax 04-01-2018 11:28 AM
Just to be clear, this is equivalent to OptimolyHT for the transmission splines, correct ?
http://forums.pelicanparts.com/uploa...1522607273.jpg
Drbraunsr 05-31-2019 09:26 PM
Optimoly is now called: Castrol Molub-Alloy paste HT
Porsche # 000-043-004-OEM
Copper colored paste
Purchased thru Pelican
http://forums.pelicanparts.com/uploa...1559363138.jpg
Buzzard95 04-22-2020 09:30 AM
When I bought my clutch parts from Pelican for my 88 911, a bought a tube of High Performance Grease made by Sachs based on my interaction with the PP Porsche specialist. Is this not the correct grease for the splines and also the clutch fork bearings?
Buzzard95 04-28-2020 02:19 PM
Since nobody answered my previous question so far, I am posting a picture of what I received with my Pelican Parts clutch order. Would someone please tell me if this not correct for my 88 911 G50 and why?http://forums.pelicanparts.com/uploa...1588108624.jpg
kevingross 04-28-2020 03:08 PM
I dunno how important it is, but Optimol HT is a little different from other anti-seizes I've used in that it appears to have a higher metal to lubricant mix. It really is a paste. I can't tell you whether that is significant in this context. I use it where I really want to be sure that a bit more metal flake stays in place. But that's just me. (My go-to anti-seize is Wurth CU800.) Cheers,
spyerx 04-28-2020 03:09 PM
So.
Nickel
Silver
Copper
Anti seize.
If cost is not a factor, it seems nickel can be used everywhere the others can at least on cars.
Is that accurate?
If what i read on manufacture websites is right or interpreted by me correctly... seems right?
donbecker1234 04-28-2020 03:13 PM
AFAIK the nickel anti-seize is the high temp, used for exhaust.
HaroldMHedge 04-28-2020 10:44 PM
The High Performance Grease made by Sachs is the correct grease for the clutch splines.
TSBs 8805 Lubrication of Clutch Parts and 8902 Modified Clutch Release Lever Shaft Bearings (for G50) call for the release lever and the contact points between the release bearing and release lever use Olista Longtime 3EP grease 000-043-024-00. This grease has been superseded to Porsche Extreme Pressure Grease 000-043-305-73.
Note that Technical Bulletin 3 911 Clutch Release Bearing for Carrera 1987-89 indicates that the guide tube and sliding surface of the release bearing should not be lubricated.
Edit
8902 Modified Clutch Release Lever Shaft Bearings (for G50) also has the release shaft bearings and the shaft cap/cover filled with 3EP grease.
Buzzard95 05-04-2020 12:33 PM
Harold, thanks for the response.
