Heat/Ventilation hose
Trying to locate some 60mm I.D. flexible hose to replace various heat/ventilation hoses in my '88 Carrera. What do folks use for this?
Thanks, Tom
1988 Carrera |
pegaus racing sells 2 types, in 2 heat ratings (higher rating is enough for heat exchangers).
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
abides.
2.5" SCEET ducting fits a little loosely, but works fine. I prefer the 2-ply SCEET over the single ply SCAT duct.
Graham 1984 Carrera Targa |
Thermoid High-Temp Ducting - 600 Degree Aircraft Silicone Ducting
Might as well change ALL of the tubing. 11 feet is enough to do 2 cars with no mistakes, or 1 car with lots of mistakes...
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
I've used the silicone tubing on my brake ducts - but the wire reinforcement is too stiff for the HVAC stuff - also, I can't seem to find anything with a 60 mm ID that is prevalent in the fresh air system.
1988 Carrera |
SCEET AIRCRAFT DUCTING from Aircraft Spruce |
