sparkplug wire set
there are a bunch of spark plug wire sets here which do u recommend, probably need to change mine since they are original ones in my 82sc and one is missing the rubber boot on top without paying for the original porsche wires
I am very happy with the standard Clewett wires I bought two years ago. I did not buy the Magnecor for my 81 but they are highly recommended. About a $75 difference in price with the Magnecor being higher.
I went with the Magnecor (KV85) wires recommended by Steve Weiner a couple of years ago and have had no problems. I did need to modify the wire guides a bit as they are thicker than the stock wires.
Happy with the Magnecor also.
^+2
Are all the above wire sets installed with out the wire mesh grounding jackets or sleeves?
My Magnecors (KV85) do not have the grounding jacket like the stock wires. When I was doing my original research there were a couple of theories about why teh stock wires were grounded that I no longer remember other than to try and contain RFI noise. I have not had any issues with my installation on a stock 82SC engine.
Magnacors, plus it looks good :D
ok thanks guess i'll go with the magnecors...........
It was more of a failed attempt by the factory to address the issue of airbox explosions due to ignition crossfire which never cured the problem. |
| All times are GMT -8. The time now is 06:15 AM. |
