My pedal cluster is thrashed!
In changing out my clutch cable, I've discovered my pedal cluster is an absolute mess and needs some work. I have the bronze bushing set installed, but there is play at every joint of the cluster. On top of that the clutch pedal helper spring is broken and I can't source a replacement. Here's a picture: http://forums.pelicanparts.com/uploa...1307900016.jpg
http://forums.pelicanparts.com/uploa...1307900132.jpg If this spring isn't made anymore, what's the alternative? |
Place a WTB post for a used pedal cluster in the parts forum.
| All times are GMT -8. The time now is 05:36 AM. |
