-   -   Can I rebuild my 915 (http://forums.pelicanparts.com/porsche-911-technical-forum/6138-can-i-rebuild-my-915-a.html)
82SC 07-16-2001 11:55 PM
is this something I can tackle with a 3 bay garage and some hand tools...or should I leave it to the pros?
One place said synchros bearings gaskets seals and clips for 750 all in one day
Motor Meister?? Maybe work with them since I am local to them (LA)
Or the Vertex exchange problem ~1000
Do you have wrenches in the area?
Or can I just open her up and switch out just the parts that are problematic...which seem to be the bearings...or is it a waste to open her up and not change out the sychros...I am looking for the most economical situation...I start med school this fall, so I am taking out 100K in loans as we speak...
Thanks guys
MJ
john walker's workshop 07-17-2001 08:22 AM
bearings are not problematic. syncros and shift sleeves are. 8hrs labor at $80hr =$640. that's in and out of the car. syncros, gasket set,1+2 sleeve, 3+4 sleeve, at least 2 sets of press on teeth, brake bands,and gear oil can double that. so at $750, you're not getting much. they're reasonably easy to do, but there are a few problems you can run into without having the proper tools and experience. get a decent manual and walk yourself thru it. it will show just about everything except changing the press on teeth.
