beepbeep's Avatar
Question Can i
Oil-return pipes on my 930 81' are leaking. I wonder if pipes can be replaced without emptying oil from the engine? It has a dry-sump, so it shouldn't be that much oil in the pipes when engine is stopped, or am i wrong?
Thanx!
Old 07-17-2001, 04:20 AM
Post
just drain the engine. no big deal. if it sits too long, it will refill and start drooling. the oil gravity feeds from the tank thru the oil pump gears.
Old 07-17-2001, 08:25 AM
