valve timing?
Does anyone know the amount the dial gauge should move on the intake valve when performing valve timing. The motor is is a 1973 911T.
Thanks Eric |
Eric,
For the MFI engine, it is 2.40 to 2.80 mm, <b>with 2.60 mm being the 'desired' lift value.</b> CIS engine is 0.90 to 1.10 mm, <b>with 1.00 mm being the 'desired' lift value.</b> |
| All times are GMT -8. The time now is 10:27 AM. |
