Engine hose clamps - reusable?
I'm planning to replace the ICV and check several other items (for vacuum leaks), and have found those hose clamps a little confusing. They look to be 'one-shots', in other words, installed at the factory (with maybe a special tool) and not reusable once removed. Is that correct? Can I replace with conventional worm screw type? Or should I track down the originals?
Thanks. |
Yes, unless thrashed, if they are OEM, keep them SAE just don't fit right and the sharp edges tend to cut the hose, another issue :eek:
BTW that upper hose on the ICV is NLA so be very careful |
Oetiker is the name; needs an Oetiker-appropriate plier to crimp them.
e.g. Hose, Tube, Fittings & Valves from MSC Industrial Supply Co. Sherwood |
Understood, thanks!
But how should I remove them? Would I need the Oetiker-appropriate pliers to remove? |
Sherwood |
Buy an Audi and you'll get very good at it ;) |
I just bought Tile Nippers for $7.00 at a local hardware store. If this ear clamps are the same design, once I squeeze it at the numb it should release.
Will be changing the PCV and hope to reuse the ear clamps if not SAE goes on. |
| All times are GMT -8. The time now is 06:54 AM. |
