3.2 carrera ... More power advice
I have a 84 carrera 3.2 engine, and I currently runs catless with Wongs chip and dansk exhaust system.
Any other suggestion on the options to get more power?
Thanks...
Old 06-17-2011, 11:37 AM
a.k.a. G-man
Geronimo '74's Avatar
I'll politely suggest you try the search function.
There are sooooo many things you can do, depending on your budget and goals.
Turbocharge it
Go from 3.2 to 3.4, 3.5
Twinplug,
The list is endless
Old 06-17-2011, 11:50 AM
Make Bruins Great Again
Por_sha911's Avatar
Before you spend money on more stuff:
-Have you checked your WOT? Is your linkage properly adjusted? Are you plugs, wires, cap, rotor, filters... in excellent shape?
-Did you dyno the car with the new chip? If not, after the above stuff I would start there. Steve can take your dyno sheet and adjust the mapping to fine tune your chip.
There are things you can do but you got the low hanging fruit. Options: SSI or B&B, Extrude hone, cams, MSD system... Most of these things ain't cheap!
You need to do a search. The pelican search button is not great but you can use Google and search Pelican 3.2 "more power". There is a wealth of knowledge already in this BBS. Start digging and you'll be amazed.
Geronimo: you beat me to it.
Joe
Old 06-17-2011, 11:57 AM
Thanks guys
Old 06-17-2011, 12:12 PM
