-   -   O2 Sensor Replacement Question (http://forums.pelicanparts.com/porsche-911-technical-forum/61438-o2-sensor-replacement-question.html)
GoodMojo 03-02-2002 05:30 PM
To ask a newbie question, how does one disconnect the O2 sensor from the side of the wheel well? Do you just slip the edge of a flathead underneath the rubber grommet and pry up?
-Wade
'88 930 slant coupe
don911 03-02-2002 06:27 PM
The O2 wire disconnect is in the engine compartment on the left side. Once you disconnect, you can use a flathead to pull off the rubber grommet.
