Quick G50 Question
My car has a 915. My buddie's RSA has a G50. We just dropped his engine/trans. Please pardon my stupidity.
Regading the clutch release fork. When we removed the shaft, I can see there is a needle bearing that the shaft rides on. But I can not find this bearing online in the Parts section here at PP. Anyone know where I can find it? Thanks in advance.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Somewhere in the Midwest
Replace the needle bearings with solid bronze bearings and a new cross shaft. That is the upgrade/fix to prevent the needle bearings seizing and breaking the ears off the case.
The kit is less than $200 and you get all the parts you need. If you are not familiar,,,search "cross shaft" |
Thanks so much.
And we also used the same "tool" to remove the shaft. Pretty sophisticated stuff.
