Risks of removing dust shields??
What are the risks / downsides to removing the dust shields from your car?
I have 76 Carrera 3.0 and looking at improvig the braking for several DE / track days a year. I thought the first steps would be to bleed brakes, replace brake lines, look at 993 scoops and removing the dust shields. I drive about 6,000 miles P/A. What are the risks / downsides to removing the dust sheilds - on the basis of my car usage - is it worth doing. * you need to expain in plain english / clarify in detail as this is all new to me please.......... thanks in advance. Kiwi 911 |
I've removed the shields and installed plates for a brake cooling kit for occasional track days. I think they've been on for 2 or 3 years without any issues.
Kiwi911,
I removed my dust shields in 1968. No problems since. The downsides occur if you drive in snow / slushy freezing conditions on the highway where you seldom use the brakes. Snow/ice can accumulate in/on the brakes. Another downside is if you regularly drive unpaved/gravel roads. There is increased possibility that a stone can lodge in your brakes. (Even with the dust shields, this is not uncommon if you spin-off into a gravel pit at a DE :eek: ) Yes, removing the dust shields increases air flow to the brakes and keeps them noticeably cooler at DE events. :cool: Ducting fresh air to the brakes is of significant benefit. I question the effectiveness and effect of a restrictor plate between the front brake rotor and hub – I don’t add the un-sprung weight. Some ‘big iron’ (5-liter racers) add water vapor cooling (like the ‘Rubbermaid Solution’) to the airstream to their brakes. This is (fortunately) unnecessary with a 911 although probably with a tracked Turbo Cayenne or Panamera it would save a set of brakes. :rolleyes: Best, Grady |
When I tracked my '76 C3 I found the brakes to be marginal, cool them in every way possible including removal of the dust shields and addition of A arm scoops is good There are much better pads and fluid available now then back then too, This is one case where SRF is worth it |
What pads would you run for 80% road / 20% track use. I wish to avoid squeeling etc. if possible. Thanks in advance. |
Apologies, but can you show me a picture of the restrictor plate you mention - I don't understand what you are saying here (thanks for you patience) |
Ferodo 2500's. No squeal. No dust. Inexpensive; Pagids add little for twice the price. Fine for street and track with decent fluid and cooling.
+1 on Ferodo 2500's. However mine squeak when warmed up!
Have you tried a bit of anti-seize on the back? Have used maybe 15 sets, have never heard a squeak
Where do you put the anti-seize? Between the piston and pad?
Yes, on the back of the pad. Smear on a very little. Some believe filing the pad lightly to bevel the edges maybe 1/16" helps too; I'm less sure.
