-   -   Check Your Fuses .... (http://forums.pelicanparts.com/porsche-911-technical-forum/614996-check-your-fuses.html)
1990C4S 06-20-2011 10:32 AM
I had an odd electrical issue where my alternator light came on when I went into reverse, and when I used my turn signals. The gauges also went dead at the same time, bit not all the time, only occasionally.
http://forums.pelicanparts.com/porsche-911-technical-forum/556253-wierd-electrical-issue.html
After I bit of searching I found the issue: A bad fuse contact face.
And when I went to replace fuse #12 I barely touched fuse #13 and it fell out.
Digging a bit deeper I found the spring tension on several of my fuses was completely gone. I had to remove the loose fuse, bend the spring tab up and re-insert the fuse.
You can rotate the fuse with your finger, if it spins too easily then you need to make an adjustment and increase the tension.
mholbrook38 06-20-2011 10:35 AM
First thing I did was to replace all the fuses and relays in my car and wire brush the contacts.
I notice that since I fixed the AC that fuse gets pretty hot. I'm going to look for a solution to that.
1990C4S 06-20-2011 10:38 AM
If you search there are some nice conversions to 'real fuses' using these (Or similar)
Fuse Block, 3AG, 6 Circuit w/ground 5015 - Blue Sea System Fuses and Fuse Holders @ MarineEngine.com
kach22i 06-20-2011 11:10 AM
I replaced all but five of my front fuses this year. The kit I bought was short or something.
Yea, some of those tabs needed to be bent up just a tiny bit. Found a couple of fuses no where near the rating they should have been too.
Time to do the rear panel, this post just reminded me.
Por_sha911 06-20-2011 01:23 PM
Make it a part of your maintenance routine to simply rotate each fuse after doing an oil change. This will ensure the contacts are clean and that the fuse is properly seated in the holder.
Trackrash 06-20-2011 02:55 PM
I had a problem where the rivets on the back of the fuse panel that serve to connect the fuses together had slight corrosion. This was causing a slight resistance and the heat almost burned up the fuse block. I originally thought it was the fuses, but after replacing them with heaver fuses I realized it was the connections on the back of the fuse block causing the problem. I cleaned the rivet heads and ran a bead of solder over them to fix it.
JJ 911SC 06-20-2011 03:59 PM
and don't forget the one's in the engine bay.
My first problem when I got the car. One of them was actually broken, not blown, just broken.
Joe
How is the hokey withdrawal going?
1990C4S 06-20-2011 04:15 PM
I need therapy. I almost watched baseball yesterday. Painted my house instead.
kidrock 06-20-2011 08:57 PM
I recently spent approximately 20 minutes by disconnecting the battery and using a small brass brush to clean every contact on every single fuse block, as well as the metal contact on each and every single fuse.
Now, everything is shining like a diamond in a goat's arse.
Joe Bob 08-18-2011 11:41 AM
My electric windows decided to die on me today.....spun the fuse they came back. Welcome back to CA and salt air.
Por_sha911 08-18-2011 01:18 PM
Baseball is slower than watching paint dry.
DonNewton 08-18-2011 01:31 PM
In the never-ending quest to find other things to spend money on (WRT the 911), has anyone converted the installed fuse block to the more modern blade fuse system? For some reason, this seems like a conversion that would mitigate some of the corrosion we see with these cars. Just wondering. . .
Joe Bob 08-18-2011 01:58 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/617872-ato-fuse-panel.html
DonNewton 08-18-2011 06:15 PM
Holy Jesus. I just thought about this when reading this thread. Maybe I should spend more time on this site.
John W. 08-18-2011 07:21 PM
+1 to kidrock use small metal brush to get them good and shiny - steel wool will also do great but you got to catch all the debris. then make sure they have good tension.
tazzieman 08-18-2011 08:31 PM
Indeed
http://www.lilypix.com/photos/data/9...935_p26968.gif
kidrock 08-19-2011 01:31 PM
Originally Posted by tazzieman (Post 6204819)
awesome!!!! :d
billybek 08-19-2011 08:12 PM
You can clean the contact tabs with the eraser on the end of a pencil. Does a great job, just give it a spin.
