Alternative fuel pump options rather than Bosch?
Need a fuel pump for a CIS 78 911. I think I saw a recent post here on the tech board that there are other options rather than Bosch for fuel pumps, Anyone used another pump rather than Bosch? Thanks
RETIRED
Walpro has a decent rep.....but having my oem pump for as long as I have tends to give it a great rep. Lot's of good used units out there.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Bosch Fuel Pump
Our host sells a new unit for <$260. For something this critical my decision was to get a new unit. Wound up buying a used unit that stopped working after a while then at a friend's suggestion bought a second used unit. So guess how much I spent on two used fuel pumps.
Just my $.02 |
Gordo
Don "Gordo" Gordon '83 911SC Targa |
grateful user
look up "the fuel pump king" in Ca. have bought several pumps from him. brand new in the box bosch pump for my sc was 165 bucks delivered, that was around 3 yrs ago and still humming. Before you call, he needs the # of the old pump.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
Flat Six
You have a PM
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Flat Six
Bosch site says part # is 69513:
![]() Hope this helps.
Flat Six
Adidas, were you able to source a pump?
Ebay, $40 pump new, works fine lets see how long it will last.
