Quick G50 Question
My car has a 915. My buddie's RSA has a G50. We just dropped his engine/trans. Please pardon my stupidity.
Regading the clutch release fork. When we removed the shaft, I can see there is a needle bearing that the shaft rides on. But I can not find this bearing online in the Parts section here at PP. Anyone know where I can find it?
Thanks in advance.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 06-21-2011, 10:27 AM
Somewhere in the Midwest
MotoSook's Avatar
Replace the needle bearings with solid bronze bearings and a new cross shaft. That is the upgrade/fix to prevent the needle bearings seizing and breaking the ears off the case.
The kit is less than $200 and you get all the parts you need.
If you are not familiar,,,search "cross shaft"
Old 06-21-2011, 10:52 AM
MotoSook's Avatar
Here you go:
G50 Cross-shaft Update
Old 06-21-2011, 10:53 AM
Thanks so much.
And we also used the same "tool" to remove the shaft. Pretty sophisticated stuff.
Old 06-21-2011, 11:31 AM
