Bird. It's the word...
Fishcop's Avatar
Question Rebuilding Konis...oil in strut?
G'morning Gurus (well it is here anyway).
I've just pulled out all my Koni shocks for a rebuild. Inside the fronts, I found the cartridges to be sitting in an oil bath....what is the purpose of this? Should I get rid of it, use it again, or replace it with new oil (what weight and how much)?
When I have the shocks rebuilt, is there anything extra I should have done whilst they are in there? These units are the adjustable ones.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 03-13-2002, 03:11 PM
PRO Motorsports
Tyson Schmidt's Avatar
The oil is in there to help transfer the heat from the strut insert out to the strut body where it can be dissipated. I usually use ATF, but it really doesn't matter what you use.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 03-13-2002, 03:42 PM
Fishcop's Avatar
Thanks Tyson,
Do I put the insert back in and then fill oil to the brim, or just half-way or what?
Cheers
John Forcier
Old 03-13-2002, 03:48 PM
PRO Motorsports
Fill it up about 2/3rds of the way, so you don't end up with a mess. Put the insert in first, then fill. If you fill it first, then install the insert, it will almost certainly overflow all the oil and make a big mess all over your brakes, etc. and you'll be cursing and cleaning. (just a guess you know, never happened to me personally... )
2004 GT3
Old 03-13-2002, 04:00 PM
Fishcop's Avatar
Terrific Tyson, thanks for your help.
PS to anyone reading this: Real easy job, much easier than I thought it would be!
John Forcier
Old 03-13-2002, 04:03 PM
