-   -   turn signal (http://forums.pelicanparts.com/porsche-911-technical-forum/615615-turn-signal.html)
NIKO930 06-23-2011 01:27 PM
turn signal
Help
Problem with my turn signal.It does not work at all. The hazard lights work fine. But turning left or right does not work.
Any ideas where to start?
DRACO A5OG 06-23-2011 01:40 PM
Check fuses are seat snug not loose, check behind the gauge to insure ground is seated and not corroded then the stalk
ossiblue 06-23-2011 05:15 PM
Draco A50G gave you some starting points, but can you clarify what you mean by "not work?" Do the lights (front and rear) illuminate but not flash or do the lights fail to come on? Do the indicator arrows in the speedo illuminate? Your answers will help narrow down the problem area.
