Weber Question ...
I have stock 911T 2.2, except the PO installed E pistons and cylinders in a rebuild. I am in the process of installing E cams. Will I need to put bigger jets in the carbs?
Gary,
Without knowing precisely what jets you currently have, its difficult to say, but the engine differences are simply a small increase in compression ratio so any changes would be modest. |
| All times are GMT -8. The time now is 09:50 AM. |
