Doug E's Avatar
How long until you felt ...
a difference once you changed tranny fluid?
I did the Swepco change in my 915 tranny today and didn't notice any improvement at all. Granted I only had time for a quick spin around the block but none-the-less I guess I was expecting miracles given all the rave reviews about Swepco. I hope to give the car more of a work-out tomorrow and see if it has anything to do with temperature but I was just wondering what everyone else experienced.
Specifics: '81 SC with 90k miles; Swepco 201 used; pumped with car level until slight trickle came out the fill plug; only a few metal shavings on the magnetic drain plug other than a small amount of milky white substance.
Other than having to cut down the size of the 17mm alllen key wrench (too long so it was hitting what I believe was the accelerator link) this project was SIMPLE!
Each one of these projects I accomplish makes me feel more like a true DIY. The advice given on this board rules!
Thanks.
Doug
'81 SC Coupe
Old 03-18-2002, 04:40 PM
Send a message via ICQ to old_skul
For me, it was immediate. You may be replacing fairly fresh tranny fluid. I was replacing fluid that was at least a year old, and there wasn't a heck of a lot in there. Less than I expected, that's for sure.
My 3rd gear synchro started working a little better after that. Also, on cold (freezing) mornings, the tranny felt like it was filled with molasses.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 03-18-2002, 04:58 PM
Just a run around the block isn't enough time to get the Swepco warmed up. My 915 is still a little difficult until it warms up.
Old 03-18-2002, 05:03 PM
