88 911 targa drain hose in wheel well
Can somebody tell me what the drain hose is in the drivers side wheel well??
Is it overflow for gas when tanking the car? Thanks
Old 06-28-2011, 12:40 PM
No. It is the overflow for the Master Cylinder. If you ever use a Power Bleeder on your brakes and forget to pinch the line on the side of the Master Cylinder, that hose will spew Brake Fluid all over your garage floor. Twice, if you are dumb like me.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 06-28-2011, 12:43 PM
The hose I pinch off when power bleeding is so small. The hose I'm referring to is probably 3 times that size. Are you sure?
Old 06-28-2011, 12:49 PM
I'll check on mine as soon as I get home. There are also AC hoses in that area.
Old 06-28-2011, 01:41 PM
On my 77 it appears to drain whatever gets into the fuel filling area. Since the door doesn't have any seals; water from rain or washing, or overfilling of fuel needs a place to go.
-Rutager
Rutager West
Old 06-28-2011, 04:14 PM
