-   -   Fuse #19 has power then it doesn't... help? (http://forums.pelicanparts.com/porsche-911-technical-forum/616638-fuse-19-has-power-then-doesnt-help.html)
Marlon Targa 86 06-29-2011 10:40 AM
Problem:
Fuse #19 which powers the rear right light assembly measures zero volts with ignition on. When I disconnect the bottom wire connected to the fuse, I measure the full 12.4 volts at the top screw op that fuse.
I connected the bottom wire to fuse #18 ( rear left light assembly) and then all the light bulbs on the right rear work. But when I connect it back to fuse #19, the lights don't work and I get zero volts.
Any clues what's going here?
Marlon
rick-l 06-29-2011 10:50 AM
You have resistance in the supply to fuse 19 >> the resistance of the bulbs. It forms a voltage divider between it and the bulbs. Clean the fuse contacts. Use your voltmeter to see where the drop occurs.
Marlon Targa 86 06-29-2011 10:51 AM
But how come the bulbs function fine when powered by fuse #18?
Or maybe I'm not getting it? Sorry, fairly new to this fuse thing.
Marlon
rick-l 06-29-2011 12:15 PM
Does this explain it?
V(batt): 12 voltage
V(case_1): 11.9502 voltage
V(case_2): 0.142292 voltage
V(case_3): 12 voltage
the 12 ohms is the 12 watts of lights.
the 50 m is the wiring resistance
http://forums.pelicanparts.com/uploa...1309374844.jpg
Edit 1000 is the corrosion on the splice/fuse
dshepp806 06-29-2011 01:59 PM
probably time for some good cleaning, retensioning and retightening on that fuse block....
Best!
Doyle
Marlon Targa 86 06-29-2011 02:09 PM
Yeah, I think I understand. I'll try jumping across the fuse and see if it works then.
